i have had my pacific 1002 for almost 2 years, in the past i have mainly played VCD / SVCD's and had no problems.
When i played orginal DVD's i got a very loud rattle noise that i solved by putting the instruction manual under the unit to cushion it.
I just bought an LG DVD writer and some datawrite white top DVD-r disks but i have been experiencing jerky playback where every minute or two the picture freezes but the sound carries on, it seems to happen most when the camera changes view quickly like during conversations or action scenes.
I am converting with TMPG Enc, authoring with TMPG author and burning with Nero Rom or the burning tool in TMPG author. I am burning at 4X.
I put one of the problem disks into my PS2 (which i didnt think played DVD R) and it seemed fine.
It looks like i might be in the market for a new player unless anyone spots anything else that i have done wrong above?
as far as the pacific 1002 rattling noises,its a balance problem,and its been going on for years,as long as they have been sold.cheap drive,and mechanism is the problem.you can fix it by opening it up and packing the struts for the drive with little bits of foam,but its too much bother,take it back to asda,and swap it for another brand they sell.
and the media skipping is just that,cheap crap media.datawrite white tops are shit to say the least,a really good disc just now is the datawrite grey topped x8speed,with either a fuji03 dye or prodiscF01.
i havent had a problem with them for over 300 burns now,and playback is fine.they cost about £5.50 for 25 from usual stockists,like blankdiscshop.co.uk -
if you mean these ones they are also quite cheap at only about a pound more than i paid for the whites
http://www.planetmicro.co.uk/product_info.asp?stockcode=M003737
are the yellow and orange ones any good? -
yep.those are the ones,datawrite grey topped x8speed dvd-r,but dont get them from there.
go to www.blankdiscshop.co.uk as there only about £5 from them,saving a few quid that way.
the yellow and orange ones are shit ,to be honest,the grey ones are the only decent ones ive tested,theres red,yellow and orange(and ive done a lot of the greys).
hope this helps.
Why DVD playback is jerky when panning?
By videdit in forum DVD & Blu-ray PlayersReplies: 2Last Post: 25th Nov 2010, 13:10 -
Jerky Playback on DVD Converted from HI8
By Funky Monk in forum Video ConversionReplies: 3Last Post: 15th Apr 2010, 10:19 -
.AVI to DVD Jerky Playback
By Bunky in forum MacReplies: 2Last Post: 27th Oct 2009, 14:23 -
jerky video playback in dvd player
By resloan in forum Newbie / General discussionsReplies: 3Last Post: 18th Sep 2009, 16:09 -
Pacific DVD-1002 hacks
By mark2004uk2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 26th Jul 2007, 10:22
