  1. It seems that all of a sudden when I try to burn a VCD with Nero5 that if I have over 2 streams on the VCD the 3rd and 4th stream won't play properly in my computer. There is audio noise and the video won't look as it should. When I try to play these streams in WMP, I get a Cd error (blue screen). I know the disc isnt scratched because I had just burned it when trying to play it. Has anyone had this problem? Help would be appriciated!!
  2. Firstly, I assume that all your mpeg files are fully compliant?
    It could be possible that Nero is incorrectly burning the files on the disc making a corrupted disc... Have you tried updating your version of Nero?
    Alternatively you could try VCDImager + CDRWin/CDRDAO.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. I used TMPGEenc with the Video-CD NTSC Template, so they should be fully compliant. I burn VCDs with 2 or less streams just fine. I upgraded Nero and it was very unstable (Im running WinME). Ill try CDRwin.
