Im looking for a program that can schedule up a load of audio rips and leave it to do it with no maintainance.
I am currently using virtua dub and its great but i have to do each file one by one.
Is there a way in virtuadub im missing ?
Is there a prog (free or pay) that will do what i need?
Is there a prog that will convert loads of avi files to vcd/dvd without audio correction problems i could do in a batch ?
Or am i doomed to just doing them one by one and waiting for it to process then starting the next one ?
Check out my sites www.bedroomdjchoice.com and www.andrewcasric.com for dj mixes, reviews, forums and more :)
Virtualdub has batching already in it - when you go to save a file, there's a tickbox at the bottom that says "Don't run this job now ....." something or other. That adds your file to the job list. repeat for eveything you want to batch, then press F4 to open the Job list. Press start and it will do its thing.
As for AVI to VCD/DVD, TMPGEnc also has a batching function built in.If in doubt, Google it. -
I know about tmpgencs batching functions.
But i cant see anything in Virtualdub like you describe, i goto save wav and all i get is the filename selection screen .... what am i doing wrongCheck out my sites www.bedroomdjchoice.com and www.andrewcasric.com for dj mixes, reviews, forums and more :) -
Lol thanks for your help .... ive found a solution though
semi thanks to you lol, ive got Virtualdubmod and you can add to batchlist on that and ive worked out howto save as a wav so im giving it a go now.
So Thanks for triggering my memory about the tick box
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Audio Editor - Batch
By BobAchgill in forum AudioReplies: 2Last Post: 3rd Nov 2011, 06:43 -
Batch mixing audio + video QT
By romanvaras in forum Video ConversionReplies: 1Last Post: 20th Jan 2011, 14:12 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Normalize audio - batch possible?
By lj01 in forum Newbie / General discussionsReplies: 4Last Post: 25th Jul 2008, 19:19
my bad - that's only available for save out the AVI, not the WAV
