I am trying to make a dvd from a .mov file and here is what I keep getting:
Encoding started on Sat Dec 18 08:18:35 PST 2004
-f 5 -b 4000 -q 3 -B 260 -V 230 -a 2
-F 4
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Using GNU internationalization
Original domain: messages
Original dirname: /usr/local/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MPlayer dev-CVS-030316-14:10-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
: No such file or directory
AltiVec found
Reading config file /usr/local/etc/mplayer/mplayer.confReading config file /Users/carey/.mplayer/config
can't open '/Users/carey/.mplayer/codecs.conf': No such file or directory
can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
CommandLine: '-noframedrop' '-vo' 'yuv4mpeg' '-ao' 'pcm' '-waveheader' '-v' '-osdlevel' '0' '/Users/carey/Movies/DI/DI.mov' '-aid' '0'
get_path('font/font.desc') -> '/Users/carey/.mplayer/font/font.desc'
font: can't open file: /Users/carey/.mplayer/font/font.desc
Can't open input config file /Users/carey/.mplayer/input.conf : No such file or directory
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Using Unoptimized OnScreenDisplay
Using usleep() timing
Terminal type `unknown' is not defined.
get_path('input.conf') -> '/Users/carey/.mplayer/input.conf'
Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
Falling back on default (hardcoded) input config
get_path('DI.mov.conf') -> '/Users/carey/.mplayer/DI.mov.conf'
Playing /Users/carey/Movies/DI/DI.mov
Not an URL!
File size is 1183760 bytes
Checking for YUV4MPEG2
DEMUXER: freeing demuxer at 0xe659d0
ASF_check: not ASF guid!
Checking for NuppelVideo
Checking for REAL
Checking for SMJPEG
Searching demuxer type for filename /Users/carey/Movies/DI/DI.mov ext: .mov
Trying demuxer 7 based on filename extension
Checking for MOV
MOV: Movie header found!
MOV: missing data (mdat) chunk! Maybe broken file...
DEMUXER: freeing demuxer at 0xe66240
Checking for MOV
Checking for VIVO
header block 1 size: 18
Checking for PVA
MPEG Stream reached EOF
ds_fill_buffer: EOF reached (stream: video)
MPEG packet stats: p100: 40403 p101: 4 p1B6: 0 p12x: 29 PES: 4 MP3: 0
Not MPEG System Stream format... (maybe Transport Stream?)
Checking for DV
RAWDV file format detected.
Unknown/missing audio format -> no sound
demux_open_rawdv() end_pos 0
==> Found video stream: 0
demux_open_rawdv() frame_size: 144000 w: 720 h: 576 dif_seq: 12 system: 2
demux_open_rawdv() seek to 0, size: 144000, dv_dec->frame_size: 144000
==> Found audio stream: 0
demux_open_rawdv() chan: 0 samplerate: 0
[V] filefmt:22 fourcc:0x44535644 size:720x576 fps:25.00 ftime:=0.0400
get_path('sub/') -> '/Users/carey/.mplayer/sub/'
Opening audio decoder: [libdv] Raw DV Audio Decoder
dec_audio: Allocating 15552 + 65536 = 81088 bytes for output buffer
uninit audio: libdv
ADecoder init failed
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
dec_audio: Allocating 131072 + 65536 = 196608 bytes for output buffer
FFmpeg's libavcodec audio codec
INFO: libavcodec init OK!
ds_fill_buffer: EOF reached (stream: audio)
uninit audio: ffmpeg
get_path('codecs.conf') -> '/Users/carey/.mplayer/codecs.conf'
*** Try to upgrade /Users/carey/.mplayer/codecs.conf from etc/codecs.conf
*** If it still does not work, read DOCS/codecs.html!
vo_yuv4mpeg: Using (default) progressive frame mode
Cannot find codec for audio format 0x56444152.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffdv] vfm:ffmpeg (FFmpeg DV decoder)
Audio: no sound
Freeing 0 unused audio chunks
Starting playback...
[ffmpeg] aspect_ratio: 0.000000
VDec: vo config request - 720 x 480 (preferred csp: Planar 411P)
Trying filter chain: vo
Could not find matching colorspace - retrying with -vop scale...
Opening video filter: [scale]
Requested video codec family [qdv] (vfm=dshow) not available (enable it at compilation)
wScale params: -1 x -1 (-1=no scaling)
Trying filter chain: scale vo
VDec: using Planar 411P as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO Config (720x480->720x480,flags=0,'MPlayer',0x50313134)
SwScaler: reducing / aligning filtersize 1 -> 1
SwScaler: reducing / aligning filtersize 5 -> 4
SwScaler: reducing / aligning filtersize 9 -> 8
SwScaler: BICUBIC scaler, from Planar 411P to Planar YV12 using C
SwScaler: using C scaler for horizontal scaling
SwScaler: using 1-tap C "scaler" for vertical scaling (YV12 like)
SwScaler: 720x480 -> 720x480
REQ: flags=0x407 req=0x0
VO: [yuv4mpeg] 720x480 => 720x480 Planar YV12
VO: Description: yuv4mpeg output for mjpegtools (to "stream.yuv")
VO: Author: Robert Kesterson <robertk@robertk.com>
INFO: [yuvscaler] SVCD output format requested in PAL/SECAM norm
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
*** [scale] Allocating mp_image_t, 736x480x12bpp YUV planar, 529920 bytes
INFO: [yuvscaler] input: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: ?
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 25.000 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 25/1 fps (~25.000000)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: ?
INFO: [mpeg2enc] Selecting SVCD output profile
INFO: [mpeg2enc] Assuming norm PAL
++ WARN: [mpeg2enc] Specified display frame-rate 29.97 will over-ride
++ WARN: [mpeg2enc] (different!) frame-rate 25.00 of the input stream
++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager"
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/carey/Movies/DI/di2.mpv
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display
INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO)
INFO: [mpeg2enc] Bitrate: 4000 KBit/s
INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 9999 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 260 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "PAL B/G"
INFO: [mpeg2enc] Progressive format frames = 0
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
error pos=71
... keeps going until...
error pos=64
stream_seek: WARNING! Can't seek to 0x119400 !
EOF code: 1
uninit video: ffmpeg
DEMUXER: freeing sh_audio at 0xe68fc0
DEMUXER: freeing sh_video at 0xe68ef0
Exiting... (End of file)
INFO: [mpeg2enc] Guesstimated final muxed size = 178357
wait, encoding to mp2 audio with mp2enc...
/Applications/Video/ffmpegX.k/ffmpegX.app//Contents/Resources/mencvcdX: audiodump.wav: No such file or directory
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/carey/Movies/DI/di2.mpv looks like an MPEG Video stream.
**ERROR: [mplex] Unable to open file /Users/carey/Movies/DI/di2.mpa for reading.
Can anyone help me with this?
-B. Zerko
I used to use the other decoder, but now it doesn't work. Do I need to buy quicktime pro?
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
Trouble with OE
By alegator in forum ComputerReplies: 4Last Post: 6th Feb 2009, 15:52 -
AC3 -> AIFF, and AOB -> AIFF for Jaguar 10.5.6?
By DeadSirius in forum MacReplies: 4Last Post: 29th Dec 2008, 15:54 -
PS/2 Trouble
By gooberguy in forum ComputerReplies: 22Last Post: 19th Jun 2008, 19:08 -
dvdshink trouble
By zookeeper525 in forum DVD RippingReplies: 15Last Post: 2nd Mar 2008, 08:42
