i have a 76+ episode series that i wanted to transfer to dvd, but using dvd movie factory i can only fit about 3 eps per dvd. i have seen the same series span across only 5. what would i need to convert the files to, to fit the most possible on each dvd? they are only about 200 mb each but end up at almost 2gb each when finished converting them.
Results 1 to 22 of 22
convert to non-standard CVD (352x480/576 with 48 mhz audio). Should be able to fit more onto a DVDr.
divx is a highly compressed video format, so converting to something else (MPEG) will only increase the file size. Something to look at is the audio, make sure that it is converting to mp2 and not pcm (uncompressed audio) -
thanks for the quick responce.
any tips on conversion software to use with this? -
www.dvd2svcd.com, but use TMPGENC or CCE for the conversion.
www.thefilmmachine.com has a converter from avi to DVD but I cant remember if it will do half D-1 (which is how some folks reference CVD (with 48 mhz audio). -
AnonymousGuest
I always have problems with the video not showing all the edges on the tv.. i heard it was called over scanning.. whut can i do to fix this? Thx
AnonymousGuesti did search, and i did make my own thread... but i figured might as well post here too, before making my own thread and wasting space.Originally Posted by jimmalenko
What, in a thread that has NOTHING to do with your problem ? That's called THREADJACKING. This thread is for Fallacy's issues. If you have the same issues, all well and good, but if they're totally different, they not welcome in this threadOriginally Posted by only_emo_kid
Back on topic, I'd recommend TMPGEnc and this guide. Make sure when doing the bitrate calculator thing you set the runtime to the length of the number of episodes you want on one disc - so if you want 4 X 30 minute eps, set it to 120 minutes.If in doubt, Google it. -
AnonymousGuestOriginally Posted by jimmalenko
it is the same issue, I have overscanning on multiple eps i'm trying to put onto dvd. -
How can I say this clearly ....Originally Posted by only_emo_kid
THIS PERSON DOESN'T HAVE AN OVERSCAN PROBLEM - YOU DO.
Get it ?
This person just wants to fit multiple episodes on the one DVD, no mention ANYWHERE of an overscan issue, so quit jacking his thread already !If in doubt, Google it. -
Too bad I got the quote already
I can't stop you, but I can remind you of the rules here. Would you like it if someone jacked the thread YOU posted for help on YOUR problem ? No, I didn't think so.Originally Posted by only_emo_kid
Please take your dose
Thankyou.If in doubt, Google it. -
AnonymousGuestnot here to fight, doesn't matter to me either, I don't care if someone comes in my thread posting their problems. so a mod clean this up ? ThxOriginally Posted by jimmalenko
If you need help with something, start a new topic. Don't threadjack someone else's.Originally Posted by only_emo_kid
AnonymousGuestOriginally Posted by Capmaster
i did start another thread after this one actually.. sorry -
You would if your thread turned into something other than what you intended and you question never got answered.
Just to re-emphasize:
On topic, I'd recommend TMPGEnc and this guide. Make sure when doing the bitrate calculator thing you set the runtime to the length of the number of episodes you want on one disc - so if you want 4 X 30 minute eps, set it to 120 minutes.If in doubt, Google it.
My DivX DVD Player can't play my avi DivX/xvid video
By Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11 -
Reconverting Divx videos to smaller Divx files.. strange resolution
By arcooke in forum Video ConversionReplies: 2Last Post: 19th Jul 2011, 03:35 -
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Philips DCP850 DivX overall quality (and DivX subtitle handling) question!
By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
