I have searched but cant find the answer.
I have checked the properties on the file and it says 6 channels not 2 or 5.
I have the ac3 codec but still wont load the audio.
any suggestions please.
Oh yes, I have also tried to remove the audio in vitualdub but it says no audio decompressor could be found but i have lame installed.
TmpgEnc cannot handle ac3 directly. You will have to install the AC3 ACM Decompressor and then either frameserve with Vdub or avisynth. The extraction of a wav file from Vdub will also work if you have the decompressor. Lame has nothing to do with it.
TMPGEnc Video Master Works audio problem creating bd25
By necron99 in forum Video ConversionReplies: 0Last Post: 29th Apr 2012, 20:52 -
MiniDV Video & Audio Problem - Corrupted, Detiriorated, Missing Audio
By 4truce in forum Capturing and VCRReplies: 14Last Post: 4th Aug 2011, 07:36 -
TMPGenc Audio Problem
By Iwan2learn in forum Authoring (DVD)Replies: 5Last Post: 13th May 2009, 10:27 -
Audio Problem using AVISynth and TMPGEnc Xpress
By 1980sumthin in forum Video ConversionReplies: 10Last Post: 27th Jan 2009, 06:27 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41
