I have a Sony camcorder that I have set to use 16:9 format. What is the easiest way to author a anamorphic DVD???
It seems TMPGEnc Author cannot do this unless I did something wrong.
Y
Is it true 16:9 or a simple letterbox ? If it's letterbox, author as 4:3. If it is true 16:9, DVD Lab will quite happily do it, although I am surprised that Tmpgenc DVD Author can't handle it.
When you encoded the footage, did you make sure it was encoded as 16:9 ?
What did you encode with ?Read my blog here.
Yes, TMPGenc DVD Author handles anamorphic 16:9 quite well.
But as 'guns1inger' points out it has to have been encoded as 16:9 otherwise DVD Author will assume it's 4:3. -
OK I will work on this more tonite.
Thanks for the confirmation.
Y
PS3 with non-anamorphic DVD
By Pliny in forum DVD & Blu-ray PlayersReplies: 2Last Post: 10th Jul 2014, 10:10 -
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 10:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 16:46 -
Anamorphic DVD Recorders?
By wulf109 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th May 2008, 16:05 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03
