Hello.
I am doing a bunch of AVI to DVD conversions with anime that has subtitles added to the video, I'm assuming in .srt format. When I encode to DVD I have to mess around with the resolution to compensate for the really bad overscan that my tv has. When I do this, at times I end up with subtitles that are kinda small on screen (but I can read them all though!). Does anyone happen to know if there is a way to extract the subs and change the font size so that when I convert to DVD they will appear larger onscreen?
Depends how you are doing it. When you convert say from srt to sup, you can pick the font size. When you use say textsub to hardencode the subs you can set the font size. When you convert via dshow and use dvobsub to hardencode you can set the font size.
In your reply, are you referring to when the subtitles are originally added to the video? From your post, it seems that way but I am not sure. What I am wondering is... is there a way to change the font size after the subs have been already added? If so, I am really clueless as to how to do so.
Changing font size/color for hardcoded subtitles
By JMantis in forum SubtitleReplies: 4Last Post: 6th Mar 2011, 19:34 -
Font size will not change size
By pgwillin in forum ffmpegX general discussionReplies: 9Last Post: 8th Jan 2011, 14:04 -
Subtitles Font Size Trouble
By gdm1134 in forum MacReplies: 5Last Post: 11th Aug 2009, 21:57 -
MKV, subtitles are tiny. How to change font size?
By anarchyx34 in forum Video ConversionReplies: 1Last Post: 14th Apr 2009, 01:17 -
Subtitles - colour and font size
By CompVid in forum Software PlayingReplies: 2Last Post: 18th May 2008, 14:18
