I've recently run into a problem I don't know how to handle.
I've been trying to burn a 45 minute clip (aorund 210 MB) onto a cd as a VCD (doing it the same way as i have been doing others similar to it) The only difference is, this clip was originally approx. 90 min. long and i've edited it to only being 1/2 of the movie. When i Go to add it to my cd it shows to have plenty of room on it..but as a try to burn, Nero errors out on me and tells me that there's "not enough Memory"
Any ideas whats going on?
Thanks!
I dont have your answer,but I noticed one thing.You say you have a 45Minute clip that's "around" 210MB.If it's VCD Compliant,should'nt it "around" 450MB if its an actual VCD encoded file? Someone please correct me.
(xy=z)(x=10mb y=1minute.Of.VCD.Video)
(just tryin' to sound smart ppl)
Odd Recording Volume Problem
By blewyn in forum AudioReplies: 5Last Post: 10th Feb 2013, 12:27 -
Odd ac3 sync problem
By mayancastle in forum DVD RippingReplies: 7Last Post: 24th Jun 2009, 21:34 -
Odd problem on file size.
By daz1976 in forum Video ConversionReplies: 4Last Post: 23rd Mar 2009, 16:35 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 17:36
