I now use Tmpgenc to encode to dvd-compliant mpeg. I need a program that will batch author several groups of files (each group contains two dvd-compliant mpegs) with really good video quality. I don't need menus. In fact, I tried GUI for dvdauthor and I couldn't figure out how to not use menus. Any help will be greatly appreciated. Thanks in advance.
-Oh by the way. This is a key................
1.) Quality is a must.
2.) It must be able to do two files into one dvd.......not all files into one dvd.
3.) I must be able to batch author.
4.) I dont care how long it takes.
5.) And all files must be dvd-compliant.
Thanks gentlemen.
Run several instances of TDA at the same time.
I've tried to think of any software that can be controlled by CLI (cos you could easily set up a DOS batch file to control everything for you), but I can't think of any and this seems like the only way ATM. Also, You could probably do it this way with any authoring app I would think (running several instances, that is).Originally Posted by lordsmurfIf in doubt, Google it.
I know DVDit! only does one at a time.
@ Dilemma
So I take it that you are *not* a programmer in any language or scripting ??
Because, as the above users' posted/suggested, you could rig up a scrip or
something. I Don't think that this is too challenging, and there is a C++ DLL
that someone created for just this example, and made it easy for everyone
(and anyone) to use in their programming language (ie, be it C++ or Delphi
or vbasic even VBA) but I don't remember the name. I think it starts some
thing like dvdauthor.dll or something I don't know. Anyways.
I've ben meaning to concock something of my own, but I'm so damn lazy
these days, and there are many people here who *do* create (and continue
to create) such tools
I think that if you ask the developer of dvdauthorgui (or the other one) about
incorporating such a feature, I can't see why it wouldn't be done.
(but I can't speak for the developer)
-vhelp -
If you do not want a menu, simply set the pause for the main menu to 0 seconds and use the Post action: jump title 1; (or jump titleset 1 menu; for multivts - Use Titlesets=on)
These settings can be done in the background dialog (right click on the menu background)
If you do not want to see the buttons, use a black background, black colored text and 99% tranparency.
If you do not want to see anything (0 seconds is ~ 1/10 second on most dvd players), you have to tweak the author.xml file. Send me a note if you need further help.
FREEWARE for batch, menu-less authoring of DVDs
By nharikrishna in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2011, 05:00 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:00 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
DVD Authoring software with Batch author?
By love2learn in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 10:20
