I had my 500A since they came out and I've written plenty of discs. Without warning, when I put a disc I simply want to read (or blanks for that matter), the busy light comes on for the regular interval, goes out and I hear a tick sound and it tries to reposition itself again I guess and this process repeats until I turn it off. Anyone have a similar problem? I plan on opening up the top (where the mechanics of the drive are and see if there's some obstruction) but I wanted to check with anyone that had a similar problem. Thanks.
I took the covers off and am operating it while I can see it trying to work. What happens is the read head goes near the inside tracks and spins up and attempts to read for a second, then the head goes to the outside, spins down and restarts. The laser lense looks fine, nothing seems out of place but I don't know what look for besides a dirty lense. Any help would be greatly appreciated.
Did you uninstall it from control panel & restart your computer? Thats the first thing you do with a 500a.
btw, what are you doing having that thing open? That laser is risky. -
Well, I recently fixed a Playstation 2 that was giving a "disc read error" (common problem actually) and I fixed it simply by cleaning the lense. It's okay, I know my way around electronics.
I have the 500A in a firewire/USB2.0 enclosure and it's only installed when it's turned on and everything is ready. When I turn the unit on, the behavior I described occurs but it never identifies the drive. Windows XP doesn't even know it's there and trying to come online.
Windows Media Server on PS3 did work, suddenly it doesn't
By sshortty in forum Media Center PC / MediaCentersReplies: 1Last Post: 13th Feb 2011, 10:59 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Suddenly, burner doesn't recognize blank DVD
By slats7 in forum ComputerReplies: 9Last Post: 13th May 2008, 11:10 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Sony DRU-820A DVD Drive suddenly burning slow
By progrocktv in forum DVD & Blu-ray WritersReplies: 3Last Post: 24th May 2007, 21:55
