When I try to convert from AVI to MPEG using TMPGENC, and use the auto setting, it sets the output file to 100% of disc capacity eg 4126MB. I then get a message saying " the file needs to be smaller than 4070MB or software player or authoring software may not recognise it. I have alwayd reduced the flie to less than 4070 (about 98.5%) but is this realy necessary or would it work at 100%
No.
If you're using the Wizard, it tends to underestimate the capacity of a disc. You can quite easily go up to about 4450MB if you're not going to add any menus or anything in your authoring program (this is video audio combined) and not have any issues at all. The "manual" mode doesn't apply this "warning".
If in doubt, Google it.
How is a Smaller File a Better One?
By happydog500 in forum Capturing and VCRReplies: 4Last Post: 23rd May 2011, 21:50 -
Best way to convert DV file to something that have smaller file size
By Cazz in forum Video ConversionReplies: 27Last Post: 8th May 2010, 07:14 -
.TS to a SMALLER file with nearly SAME QUALITY
By Benygh in forum Video ConversionReplies: 2Last Post: 12th Dec 2009, 11:23 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 21:48 -
how do i make a file smaller?
By Sanosen in forum Newbie / General discussionsReplies: 5Last Post: 28th Sep 2007, 23:57
