  1. I'm not to sure if this matters but what is the best order to install the OS and video Drivers and Direct X and SP2 ?
    I normally install Video Drivers, then Direct X, and then SP2 is this the best way ??
    Thanks.
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Thanks.
    Hello,
    Doesn't SP2 INCLUDE directx????
    Kevin
  3. Banned
    Sep 2004
    Inner Circle of Thought
    Thanks.
    It really doesn't matter what order you use.
  4. Best way and most reliable for me
    OS
    Chipset (motherboard) drivers
    Video drivers
    Audio drivers
    LAN card drivers
    miscellaneous card drivers
    Service Paks and hot fixes
    Ghost
    Save for the next time I want a clean install
    Originally Posted by jagabo
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I've never found it to matter which order, especially since I've made an XP w/ SP2 slipstreamed install disc
    My order is:
    OS
    Drivers in the order they appear in the Device Manager
    Windows Update
    If in doubt, Google it.
