Processor = Intel 2.6 Ghz with Hyperthreading and 800 FSB
MBO = Asus P4C800-E Deluxe
RAM = 1 GB DDR 400
Primary Master = 80GB Maxtor 8mb Cache
Secondary Master = 80GB Maxtor 8mb Cache
RAID = (2) Western Digital Raptor 10,000 RPM Drives
In Adobe Premiere 6.5, whenever I set up to capture on my RAID drives, I drop a frame every 2 seconds. Yet, when I capture on my Secondary Master, I either drop no frames or maybe one frame an hour. The guy at the comp. store says I may have the cluster size on my RAID drives set too low for capturing video, but wouldn’t the 10,000 rpm rotation speed counteract that?
How in the _ do you change the cluster size of hard drive, much less, a RAID drive?
Originally Posted by clothesburner626
http://www.tweakxp.com/tweak2117.aspx -
To change the cluster size:
Format and specify in the dialogue box which cluster size you would like.
If formatting is not an option, a util such as Partition Magic can change cluster sizes, though you're out of luck here since PM cannot do much if you're using an NTFS5-formatted partition.
Both options are viable for any type of setup - RAID included. Is it the the ASUS hardware or WinXP striped/RAID type? WinXP's software RAID has overheads which can hinder performance rather than enhance it in case you didn't know.
Either way I'd recommend formatting a partition at the front of the disk(s) for best performance or the whole of the disk(s). Magic it may be but Parition Magic is not flawless.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14 -
Cluster Encoding?
By siwel_is in forum LinuxReplies: 5Last Post: 25th Dec 2008, 10:12 -
Shared storage for two node cluster using FC-AL and JBOD?
By cybertheque in forum Capturing and VCRReplies: 0Last Post: 1st Oct 2008, 03:45
