Here's what I'm trying to do.
1. Capture a video frame from a movie and save it to disk.
2. Cut out a portion for use on a dvd menu (like cropping a photo).
I'm not sure what the terminology is for doing this, thus my searches have not gone well.
I have DVDLab, Editstudio, MS Digital Video suite and other programs on my computer.
Thanks for your help
Jim
which part of that are you currently not able to do?
- To extract the image, you can use PowerDVD (or any other DVD player that has a "snapshot" feature). Or DVD2AVI (free, lets you save a bitmap at an arbitrary place).
- To edit the image, anything will do (including paint!).
- Then to use that as a menu, I guess DVDLab lets you do that...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
You may use GUI for dvdauthor. With the integrated Chaptereditor it is easy to save (and crop) pictures to be used in menus (main menu and chapters menu) if your source is MPEG2.
You may use the Chaptereditor as a stand alone program either, if you prefer to author with DVDLab.
Doku: https://www.videohelp.com/~gfd/ChapEditGFD_eng.htm
Download: https://www.videohelp.com/~gfd/download/ChapEditGFD.zip -
I agree. GFD is really a great piece of software with alot of options, including like borax said what you want to do. Plus its free.You may use GUI for dvdauthor. With the integrated Chaptereditor it is easy to save (and crop) pictures to be used in menus (main menu and chapters menu) if your source is MPEG2.
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Make menu for a movie dvd that have subtitle and have not any Menu!
By p_samimi in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2009, 14:29 -
DVD Menu with Chapter and Menu Template.
By big-boo in forum Authoring (DVD)Replies: 3Last Post: 17th Mar 2008, 06:20 -
dvd menu and sub menu program
By mikeoliver1313 in forum Authoring (DVD)Replies: 7Last Post: 20th Jan 2008, 11:31 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 11:36
