  1. I do Digital Audio Recording on the same computer as I capture and edit video. For that reason, I have the sound card that’s built into my motherboard disabled and use my M-audio Delta 1010 for all audio. While I’m capturing video, I get clicks and pops that do not follow to DVD. In other words, I hear clicks and pops in the audio while capturing, but when I burn to DVD, the clicks and pops are gone. WTF? My sample rate within the M-audio Delta 1010 control panel is locked to 48,000 htz. I’ve tried unlocking it but that does not correct the situation. Any suggestions greatly appreciated.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Why is it a problem if it isn't on the burned DVD?
    It sounds like it's in your playback and not in the recording side. Unless the noise is really annoying, it doesn't sound like a big problem. You could check your speaker cables and maybe try reducing the WAV Playback volume in Audio Properties.
  3. I wouldnt think it to be a big deal if the fianl DVD doesnt have the pop sounds, Maybe the source does and your card takes care of if...Maybe???
  4. I type to slow..... you beat me to it....
  5. Master of Time & Space Capmaster's Avatar
    Feb 2004
    8) We both said basically the same thing ...soo ....you get the credit for this one
