hey guys i have some divx and xvids that have qpel and gmc in them,,i have the philips 642 which doesnt support this playback,,,whats a good prog to reencode these to xvid without the qpel or gmc in them,without losing quality
Results 1 to 14 of 14
You will lose quality. Any re-encode will lose quality. Will you notice? Probably not.Originally Posted by catdaddio6
Anyway, try virtualdub. -
Wait.I have seen somthing to remove GMC without reencoding. Here read this www.videohelp.com/forum/archive/t245290.html
You can't remove GMC without re-encoding. If you are refering to MPEG4Modifier, they were talking about using to unpack bframes, which is an issue with MediaTek based players.
Pretty sure that I heard that the player can handle DivX's 1 warp point GMC ok. -
ok i used virtual dub to renencode with open dml settings,,but i cant get it to remux my audio
Have no idea.Just saw that thread. Mine wont play with GMC, if i try and it doesnt, i forget about it..LOL...not worth the Time to re-encode.Originally Posted by celtic_druid
Open silent avi. Select audio->wav audio (it must be wav AFAIK).Originally Posted by catdaddio6
Then you can select audio->full processing mode, Audio->compression, and select you favourite audio codec (mp3), configure. Select video->direct stream copy, then file->save avi. -
Use virtualdubmod to mux in the audio.
my recode looks like crap!! i used vdub fast recompress with xivd at a slightly higher bit rate,open dml and it looks very noticably different than the original whick was perfect,,,any help or ideas
Well you were warned. One thing to try is to filter or crop/resize so as to not compound artifacts by using the same macroblocks. Could also try a different quant matrix, how large was your first pass filesize compared to the original file? You did do 2 passes right?
no just one fast recompress pass,,i'm trying to do away with the qpel and gmc so i can view in my dvp642 player,,,the size stayed the same i just bumped up the bit alittle
thats fine but everything is starting to use gmc and qpel it seemsOriginally Posted by canadateck
I hear you on that..One step forward..Two Steps back. It will be an endless search for the player that plays all.Originally Posted by catdaddio6
As far as I know no current or soon to be released chipsets can handle 3 warp point GMC. I really don't think a lot of stuff uses GMC though.
So for tha player that plays it all, I guess an XBox or a PC is the way to go.
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
