    Mar 2004
    After a scheduled cap event how do you set mmc tv to turn off? Maybe I didn't give it enough time or something but when I tested this function it seemed to keep the mmc tv 'on' after the cap was finished...
  2. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Click on edit for the scheduled event, and toward the end should be a place to check shut down after capture. When I get home this afternoon, I'll do a screen capture to show you.
    Mar 2004
    Cool.. I'll look for that.
    Do you have to do that for each event or can you make it a global setting?
  4. Aging Slowly Bodyslide's Avatar
    Feb 2002
    I think you set it for each event.
  5. Aging Slowly Bodyslide's Avatar
    Feb 2002
    Mar 2004
    kinda blows that you cannot set that as a default...
    Thanks for your help!
