Hello Again peoples.
Ok, so I have my Anime Fansub issue squared away, but now I'm having another problem during the acutal burning process. please keep in mind im still a mild newb at this...
When I burn my dvds, for what seems to be no reason at all, the audio will be cut for a segment of the dvd. It happens once a dvd, never in the same place, and ends at the end of that segment. (meaning each break i put in the episode so i can skip to parts) I usually put in 4 breaks so i lose the audio for 1/4th of the episode. I have no idea what is causing this, nor do I have any idea how to solve it. I make sure to test the whole thing before I burn and every clip has sound. and I always burn at a slow speed.
My first Guess that it might be my program. I have been using Roxio Easy DVD Builder 6. (i know, theres better, but it came with the burner and thats all I can afford for now.)
I highly doubt that its my burner, as its still fairly new ive only burned say 8 discs at most. But incase you need to know its a TDK IndiDVD+-R RW CD 8x (which i never burn at)
The program is fairly simple, so i doubt that i am hitting anything to make it do so. But if someone else has had this problem maybe they could fill me in on what I am F'ing up.
Anyways, if anyone can help me with this it would be greatly appreciated.
Cannon out
Results 1 to 14 of 14
"THEY WILL ALL TASTE OBLIVION! Which tastes just like red bull, Which is DISGUSTING!" - O'Malley
Quit using ROXIO.
Get a real encoder.
Get a real authoring program.
And then burn with something.Want my help? Ask here! (not via PM!)
Hey thanks. I somewhat figured out that might have been the issue. Now then. do you have any suggestions perhaps? You tell me to use someting different, what should I use? or does someone know WHY this is doing this?
"THEY WILL ALL TASTE OBLIVION! Which tastes just like red bull, Which is DISGUSTING!" - O'Malley -
Here's what I use ... and like ... and which gives me good results ...Originally Posted by lordsmurf
(1) encoder - TMPGEnc Plus
(2) authoring - TMPGEnc DVDAuthor w/ac3 plug-in
(3) burn - Nero -
I haven't even read the story, just the title - it's Roxio.
Piece of shit - that's all you need to know.
rk1958's advice is what I'd do to.Regards,
Rob -
There are frreware tools that will do a decent job. Try dvdauthor gui (authoring), QuEnc (encoding), or Diko (everything) Nyah Levi
I encode with AviSynth and Cinema Craft Encoder aka CCE BASIC.
I use TMPGEnc DVD Author and go as far as using it to create an ISO image file.
I then burn that ISO image file with DVD Decrypter.
- John "FulciLives" Coleman
P.S.
Roxio sucks donkey balls
Can anyone explain to me why the dvd audio is being cut out. until i can get the bucks to buy a decent program, im stuck with roxio. I would like to know exactly why its happening if there is a temporary remedy for it. If not, ah well. guess im outta luck. Thanks.
Cannon out"THEY WILL ALL TASTE OBLIVION! Which tastes just like red bull, Which is DISGUSTING!" - O'Malley -
I really don't like saying this but take a look over to the left of the page. Look at some of the guides and tools. Every one here does things differnet, and have their own reasons and opinions as to why. See what freeware you might want to try and go for it. The more that you learn about different soft ware and the settings the more you learn about all of video. I don't have a clue about why yours is acting like that, Maybe try it without the chapters to see what happens?
IS IT SUPPOSED TO SMOKE LIKE THAT?
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 17:30 -
Stupid Flanders with his stupid iLoHD04 problems!
By Batchman in forum DVD & Blu-ray RecordersReplies: 33Last Post: 4th Mar 2011, 18:41 -
Roxio ?
By reygato in forum EditingReplies: 3Last Post: 20th Apr 2010, 08:50 -
Has Roxio Gone Too Far with Toast 9?
By terryj in forum MacReplies: 11Last Post: 28th Mar 2008, 15:54 -
Roxio vs Nero
By gthorley in forum Authoring (DVD)Replies: 25Last Post: 23rd Aug 2007, 03:08
