Results 1 to 11 of 11
    Apr 2003
    San Jose, CA USA
    After back up movies, I like to print the dvd round labels and stick it to the disc. Where do I get the photos of movies in round disc format that I can copy and paste and print actually like the original disc? I can get a lot of photos in rectangle format, but not in round. Thanks.
    Sep 2003
    You can scan the disks.
    Apr 2003
    San Jose, CA USA
    I did that but not in good sharp and result.
    Sep 2003
    I suspect that any you find to download will be the same. Try scanning at a higher resolution.
    Filters. Higher res.
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I use www.cdcovers.cc for any that I don't scan.
    Most printing programs and CD/DVD printers will accept the "square" images and only print what they need to print.
    If in doubt, Google it.
    Apr 2003
    San Jose, CA USA
    Cdcovers.cc is all I'm looking for, what a great help, thanks a lot.
    Sep 2003
    Yea, I just tried it and it has a lot of covers and labels. Not all of them are perfect. But man is that site loaded with all kinds of popups and what I suspect is spyware, if you allow it to download. Also, the site doesn't work correctly with Firefox. Sometimes the lists are blued in sections. Anybody get this?
  9. My prefered site is http://daprogger.mine.nu/
    Originally Posted by jagabo
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    It does have a lot of pop-ups and stuff, and that is discussed here in a couple of different threads, but IE w/ SP2 blocks everything, so it's not too bad.
  11. Member RickTheRed's Avatar
    Aug 2004
    Up north
    You can try http://www.customcdlabels.com
    Some lacks resolution but the images are always nice.
