i have van helsing dvd and it locks briefly 3 times as it starts a new section then plays fine until it reaches the end again. i have tried re ripping with dvd decrypter but it wont read over the pause and i have tried dvd2one but that shows 3 files all of approx 40 mins each is there a way of getting this disc to run smoothly, any help would be appreciated....thanks
If you have a defective DVD you should return it for a replacement.
When you say "re-ripping" do you mean you are re-ripping your original DVD, or re-ripping your copy?
Is it your original DVD that is locking three times, or is it your copy?
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Sounds like something happened when you backed up the original. Best bet is to simply re-reip from the original then try to splice everything back together.
If the original is lost/broken/defective, better to just take it back and ask for a new one.
How do you burn these files to a bluray disc?
By sdavis9 in forum Blu-ray RippingReplies: 1Last Post: 1st Aug 2010, 13:57 -
How to re-burn these files back to disc?
By Chana1 in forum Authoring (DVD)Replies: 7Last Post: 26th Apr 2008, 00:34 -
Can I Put Video Files And Picture Files On Same Disc?
By Lennoxtown in forum Video ConversionReplies: 3Last Post: 29th Dec 2007, 06:05 -
Van Halen Reunion Tour with David Lee Roth
By stiltman in forum Off topicReplies: 4Last Post: 19th Aug 2007, 22:44 -
Cannot Locate Or Open Files On Disc.
By Lennoxtown in forum DVD RippingReplies: 3Last Post: 11th Aug 2007, 06:07
