I have a bunch of videoclips and eventually it gets hard to remember which clip is which using names only.
So, my solution is to make those spiffy sample pages consisting of a series of frames from a clip/movie, captured and put together side by side.
Currently my idea is to extract frames every so many seconds/minutes using ImageGrab and then assemble them into "contact sheets" using photoshop's batch function.
However, when I have many clips to process I can imagine it gets to be a pain doing it this way.
My question is whether anyone knows of an easier way, perhaps even streamlined into a single application that will do the whole process in a snap?
Results 1 to 1 of 1
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 6th Sep 2012, 23:42 -
Need a free program that I can screencap dazzle recordings
By Velocity Eleven in forum Capturing and VCRReplies: 1Last Post: 30th May 2011, 14:50 -
Create Menu with 2 or more pages
By Phototechman in forum AudioReplies: 2Last Post: 15th Feb 2010, 09:37 -
Is it possible to have more than 2 or three pages of recent topics?
By yoda313 in forum FeedbackReplies: 2Last Post: 20th Sep 2009, 09:13 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26
