  1. I want to encode an avi file to a svcd following instructions of DIVX -> SVCD CONVERSION WITH FFMPEGX 0.0.9 encoding with QuickTime, I'm using quick presets SVCD MPG2enc and after the encoding process I don't receive as expected the img files on my desktop. Only works encoding with mplayer. Is there something to do with that problem or I should encode with mplayer and the results are the same?
  2. You should make sure that there are no special characters in your disk name or path name.
  3. Macintosh HD. That is the name of my disk, should be MacintoshHD?
