Look forward to advice,
Bruce
Results 1 to 10 of 10
You can passthrough AC3 5.1 audio with mencoder and ffmpeg engines, from VOBs, MPGs, AVIs, and other supported formats.
i give up...
i dunno how to encode a dvd-folder (video_ts) with mencoder or ffmpeg codec with passtrough 5.1.
as you can see down in the log-excerp, it did automatically switch to 2 channel sound.
i used mencoder (because it can crop the image and has more options)
i used passtrough
i used encode audio
what am i doing wrong?
javascript:emoticon('
Encoding started on Sat Dec 18 16:03:04 CET 2004
MEncoder dev-CVS-041116-19:27-3.3 (C) 2000-2004 MPlayer Team
AltiVec found
CPU: PowerPC
Reading /Users/admin/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf.
AVI file format detected.
Using pass3 control file: frameno.avi
VIDEO: [oNrF] 720x576 24bpp 25.000 fps 0.8 kbps ( 0.1 kbyte/s)
Reading config file /Users/admin/.mplayer/mencoderfont: can't open file: /Users/admin/.mplayer/font/font.desc
libdvdread: Couldn't find device name.
Font /usr/local/share/mplayer/font/font.desc loaded successfully! (206 chars)
Reading disc structure, please wait...
There are 10 titles on this DVD.
There are 17 chapters in this DVD title.
There are 1 angles in this DVD title.
success: format: 0 data: 0x0 - 0x5fc3c800
DVD successfully opened.
MPEG-PS file format detected.
VIDEO: MPEG2 720x576 (aspect 3) 25.000 fps 9608.0 kbps (1201.0 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x576 fps:25.00 ftime:=0.0400
The selected video_out device is incompatible with this codec.
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale w=672 h=384]
Opening video filter: [crop w=702 h=428 x=10 y=75]
Crop: 702 x 428, 10 ; 75
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 576 (preferred csp: Mpeg PES)
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
audiocodec: framecopy (format=55 chans=2 rate=48000 bits=0 bps=16000 sample-1)
Writing AVI header...
ailed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder libmpeg2-v0.4.0b
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
This is a mencoder limitation, its muxer only supports 2 channels. ffmpeg has no such limitation but does not support VIDEO_TS input (you need VOB input).
so there are 2 ways:
either i rip with mencoder, wich supports cropped image and video_ts
or i rip with ffmpeg, with 5.1
if i rip with ffmpeg i cannot rip a whole movie, but only every vob file seperatly...
wicked situation... hehe
is there a way to rip video with mencoder in 1 step and
the aduio with ffmpeg in 1 step and mux it together later?
im just searchin for a convenient way to convert a dvd to divx with 5.1 sound without having to fumble around too much.
the goal is to have all my dvds available on tv over an eyehome (elgato) and watch them with sourround.
otherwise your frontend is just great!
(besides: 2 or 3 pass encoding only suggests bitrates for built in cd-sizes but not the custom input in megabytes i wish to achieve in the end)
regards and tnx!
luxi
Has it occurred to you that you can open that DVD Folder with MPEG Streamclip, choose to open all VOBs, then convert to one MPEG? That way, ffmpeg will have the complete movie as one MPEG. Or maybe go back and rip with YadeX or 0SEx, choosing to save as one VOB or streams, again giving ffmpeg one complete movie to work with. You're not being creative 8)Originally Posted by luxirom
well...
many tnx for all your help!
those tools are great help indeed
to broaddd: what exactly do you select in settings to get such a result?
1. select the vob file
2. select mencoder mpeg4
3. select passtrough
4. select "encode audio" ?
because that was what i tried.. and as major writes... mencoder is not able to handle 5.1
not encoding nor passtrough.. at least here at my side
so i'm allmost happy...
now i only need to be able to crop the image to get rid of the black bars at top and bottom... since i need mencoder that for, it doesnt help to have a single vob file as mentioned.
i will crawl through all those nice apps i just found thanks to your help...
anyway: is it that rare to encode dvds with 5.1 sound??? i mean.. g5's have optical out, elgato has... no problem to get the full dvd-advantage...
regards luxi
ok!
figured out everything and it works!
nice tools you gave me here
but:
i get audio out of sync!
if i select passtrough or ac3 (5.1), the audio is out of sync...
the weird thing is: if i select normal stereo sound, sync is ok!
(source: vob file, encoding with ffmpeg)
anyone knows the solution to this problem?
regards luxi
AC3 codecs
By hawkeye48 in forum AudioReplies: 6Last Post: 1st Apr 2012, 07:17 -
DVD-compatible AC3 Encoder
By roflwaffle in forum AudioReplies: 2Last Post: 14th Apr 2011, 14:42 -
Sony Vegas + x264vfw - no compatible codecs found
By Bucic in forum EditingReplies: 2Last Post: 16th Jun 2010, 04:28 -
AC3 / DivX Compatible Players
By nordicgreen_8 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th May 2007, 08:35 -
Dvd Vobs: change audio from LPCM to AC3 2.0
By biancolone in forum Authoring (DVD)Replies: 3Last Post: 14th May 2007, 07:16
