hell O got a Mydvd 5.2 ,and Arcsoft movie maker ....I burned my discs and Im cannot see it in my tv...what I need to do.....I just can see it in my PC..please help...thanks
hmmm ....
well first quesion i guess is
1. do you have a dvd player ?
need some more info ... on exactly what you are trying to do .. and your settings .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Stick your DVD to your TV screen with tape or glue and then watch it?
Seriously though, what do you want us to tell you from your question? -
I'd suggest you put the DVD in a DVD player that's properly connected to your TV. Turn on the TV, be sure the DVD player is on and press the play button.
If that doesn't work, let us know what happens when you try it.
Could a DV file be watched from an external USB2 Drive?
By Gibson's Squares in forum Newbie / General discussionsReplies: 5Last Post: 2nd Feb 2011, 08:03 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
How to save a video from a website, when the video can't be watched in my c
By Remyisme in forum Video Streaming DownloadingReplies: 2Last Post: 31st Aug 2009, 18:00 -
TV Shows/Movies You've Recently Watched
By Soopafresh in forum Off topicReplies: 14Last Post: 8th Feb 2009, 09:52 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29
