I have a few very large .avi files that I am trying to convert to a vcd and then burn it on a cd with Nero or EZCD. But, the problem is that the avi's I'm starting with (not my rips) are DVD rips that are around 650 - 750 MB in size, so some of them won;t even fit on a CD pre-conversion. How do I make them stay the same size (or even get smaller?) while converting to .mpg with TMPGEnc?
Thankz,
-Blarb
The simplest answer is this - if the movie is 80 minutes or less it will fit on an 80 min CD in VCD quality. If it's longer than that, it won't. If you care to go lower than VCD quality, by lowering the bit rate of the video or audio and making an XCVD, then you can fit more on the CD. Maybe you should read some of the guides to get some background information before you jump in with both feet.
Fitting more onto a DVD
By Woolen Llama in forum Authoring (DVD)Replies: 14Last Post: 23rd Sep 2010, 07:31 -
Fitting more in the dvd
By btkuehn in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2008, 17:53 -
Help Fitting Videos on CD...
By skinnerback in forum Video ConversionReplies: 4Last Post: 4th Sep 2007, 17:12 -
fitting more than 1 film on a dvd - help!
By welshgal in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2007, 13:16 -
Fitting more onto single DVDs
By ells6363 in forum Authoring (DVD)Replies: 32Last Post: 18th Jun 2007, 03:57
