Can you convet an .avi file to mpeg2 with TMPGEnc plus. It is giving me an error message when I try?
Thanks for any help
Dan
Many knowledgeable people will be around to help you in due time. In the meantime, could you be more specific about the AVI info, and what error message you are getting? That really helps others help you.
While you're waiting, you might want to read several of the excellent Converting guides over there to your left. No, your other left! <<<<< -
The error message is saying that TMPEGenc can not open the .avi file, or it is unsupported.
Thanks, -
might want to read this while you are getting the avi file info that is required before we can help you much ..
https://www.videohelp.com/forum/viewtopic.php?t=189187"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Could you run it through AVIcodec and tell us what the results are? There are many types of AVI. Maybe XVID with MP3 VBR audio which TMPGEnc doesn't like? AVIcodec or Gspot will tell you what codecs are needed.
Also, can you play the file on your computer?
It also helps greatly to fill out your computer profile. -
If in doubt, Google it.
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
new Virtualdub MPEG - still a colorspace problem with MPEG-&
By sanlyn in forum EditingReplies: 6Last Post: 10th Aug 2009, 23:18 -
How to convert an MPEG file to DV-AVI Type 2 using MPEG Streamclip
By MAdNEZ in forum Newbie / General discussionsReplies: 15Last Post: 4th Aug 2009, 08:30 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DGIndexed MPEG or AVI wrapped MPEG best for AVISynth?
By flywitness in forum EditingReplies: 1Last Post: 12th Sep 2008, 10:08
