After capturing (VHS2DVD) and converting with TMPGEnc , audio quality is bad no matter if I choose 192 or 128 or 112 for audio bitrate. And Im not talking about hi fi music but for dialogues in family footage etc. I was expecting just not to have such a difference or slight distortion in some cases. Do u know what I need to do? I use the tooLame as plug in in TMPGenc because as everybody says TMPGenc is a bad encoder for audio.
Thank you in advance
KONX OM PANX
You are right that the info was incomplete
I capture PAL VHS tapes with a FlyTV Platinum card (chipset Philips 7133) in avi with huffyuv codec using capturing feature of MainConcept . The sound option is for mono (since the source is mono) 16 bit, 48000 (for DVD compliance)
The sound card is the one coming with the Compac Evo type PC, meaning that I m aware that is not a good one but the avi is with decent sound, not very good but decent.
I encode with the TooLame plug-in in TMPGenc , Mpeg layer2 (living in a PAL coyntry) and I have tried mono (for saving HDD space) , 192, 128, or even 112 because the footage is not for music but simple enviromental sounds, people's talking etc.
I am not having exptectations for spectacular results but only for a decent sound in mpeg as in the avi, the voices of familiar persons to be recognisable, with no distortion etc
I dont know if any kind of filter would improve the situation, or any other method of the encoding of sound
Thank you againKONX OM PANX -
Originally Posted by funkguy4
Anyway, I don't think that's a good idea. The audio from a VHS player is analog, there should be no problem sampling at too high a frequency, but there will be a problem if the sample rate is too low. There may also be problems if you resample the audio later, so I suggest that sampling at 48kHz (if the eventual target is DVD) is the correct way to do it.
Perhaps the noise reduction filters in Goldwave could help clean up the sound: I suspect that its simply noisy, so the encoder is wasting a lot of bits encoding the noise, which reduces the sound quality overall.
Help please! Easycap DC60 no audio and bad quality video problems!
By thorn1414 in forum Capturing and VCRReplies: 2Last Post: 17th Oct 2010, 09:24 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 19:45 -
Bad video quality when encoding in Premiere Pro CS3
By Rocky88 in forum EditingReplies: 2Last Post: 5th Sep 2007, 23:56 -
nero with bad audio quality?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 1Last Post: 3rd Sep 2007, 04:07
