When I capture my video from my DV camcorder, it is in mpeg 1 format. Can this be burned to DVD or do I have to convert it to mpeg 2.
Do I gain any quality in converting it to mpeg 2?
Thanks, I know these are basic, but I can't seem to figure them out.
Dan
Hi Dantart,
Use the latest (beta 2.52 I believe) version of GSpot (freeware) to get the details on your MPEG1.
If they match any of the valid details in the "What Is... DVD" (top left of the page) specs then you're good to go.
If not, you'll need to do some work.
My suspicion is that the resolution and framerate will be OK, but the audio is may not be the require 48,000Hz (48KHz).There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
your dv camcorder ussually spits out DV files - not mpeg files ...
Thanks for the quick response,
I was having trouble burning the mpeg 1 to dvd with Nero. Is it possible to do?
Are from Melbourne Australia, I just spent two weeks in NZ and then Cairns - Awesome Countries!! -
Originally Posted by Dantart
Yes. Read up in the guides section. The MPEGs have to be valid - see the specs I referred you to above.
I agree...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Standard technique (for highest picture quality) is to directly transfer the DV material from the tape to the hard drive (DV tape to DV-AVI file). Set Nero-Nerovision to DV format. Files will be approx 13.5GB per hour.
Next edit your material in DV format and only then, encode and author the MPeg2 DVD. Follow the Nero instructions.
Other, lower quality paths to a DVD exist.
MPEG question
By jodiann87 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 6th Jul 2008, 15:44 -
Vob to mpeg-2 question
By ChrisXP in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2008, 23:16 -
Mpeg-4 Question
By kidcash in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2007, 09:54 -
avi dvix, mpeg quicktime dvd quality question
By minmin2003 in forum Newbie / General discussionsReplies: 2Last Post: 26th Aug 2007, 12:16 -
Tsunami-Mpeg DVD Author Pro Transcoder Question
By RKelly in forum Authoring (DVD)Replies: 6Last Post: 16th Aug 2007, 21:51
