I have a ton of Video CD's files from capturing tv shows (.mpg files). The problem is I had the line in level too low when capturing so I have to turn my tv volume up a lot to watch the shows.
Is there a simple program where I can raise the level of these files, preferable in a batch format, since I have so many?
Something that works like MP3Gain for mp3 files would be great!
Unfortunatly no,you could demux the audio and run it through TMPGEnc increasing or normalizing the volume,then multiplex the video and audio.
Why not convert the VCD's to DVD?By using a program such as Ulead VideoStudio you could increase the volume and put 4-5 movies on one disc(more if you use DL). -
Ok, I think I've figured out a way. You'll need to download 3 command line apps, plus a little batch file I created to automate the process.
BTW- This is ONLY for MPEG1. If anyone wants the same for MPEG2, just let me know. It's a minor modification.
DvdAuthor http://sourceforge.net/project/showfiles.php?group_id=59028
BeSplit Beta http://dspguru.notrace.dk/BeSplitv0.9b6.zip (it MUST be this version)
MPGTX http://prdownloads.sourceforge.net/mpgtx/mpgtx.zip?download
Unzip all the programs into the same folder
download this batch file run.bat
Copy run.bat into the same folder as the other files
Copy your MPEG file into the same folder as the other files.
the syntax is - run.bat whatever-your-file-name is.mpg
this will leave the folder with your original mpeg file and a new mpeg, called NEW_youroldmpegfilename.mpg
Increasing Video Volume
By edlimym in forum Newbie / General discussionsReplies: 2Last Post: 24th May 2010, 06:41 -
[Solved] How to normalize various wav files to same volume level?
By freebird73717 in forum AudioReplies: 3Last Post: 30th Sep 2009, 16:22 -
Increasing volume in GKnot
By Fire Foxer in forum EditingReplies: 6Last Post: 7th Aug 2009, 08:08 -
increasing volume in mp4 video
By snafubaby in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2008, 00:05 -
increasing the volume of ac3 files
By virendra in forum AudioReplies: 4Last Post: 1st Nov 2007, 03:25
