Ok so I have this foreign dvd, and the english subtitles will not appear when selected. I want to fix this as I dont speak cantonese
The subtitles appear ok when the dvd is played on my computer through windvd - but they do NOT appear when played through either of my dvd players.
So, in order to try and fix this... I ripped the vobs to my harddrive and I used dvd shrink to reauthor to make sure the english subpicture stream was automatically selected when played.
I burnt to disc and still no joy on my dvd players (worked ok on my pc again).
What can be done? Can IFOEdit fix this? If so how?
Hope someone can help, I still have this movie ripped to my HD via dvd decryptor.
Here's something you can try. Force them to show with PgcEdit (free):
Load you DVD in PgcEdit, find the movie PGC (the longest one), and insert a SetSTN command at the top of the pre-command area, selecting the right subtitle stream. Save and check that it works before you burn.
It's still strange that your PC can show them but not your settop box...
JeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob. -
Thanks for that.
I downloaded it and had a look, its a bit complicatay.
So I didnt know what to do - even after reading your guides. If you can help out Id appreciate it.
I did try it with IFOedit, I opened the IFO files and changed the english subs to be "forced", saved and burned.
But that didnt work either -
OK, here's how:
- open your DVD. in PgcEdit
- In the "Option" menu make sure that the option "Automatically renumber GOTOs ..." is selected.
- Look for the movie PGC (on the left panel). It will most likely be the one with the longest play time. If you're not sure, you can preview it by hitting the "`" key (the one below the Esc key).
- Select the movie PGC by single clicking on it, check that the subtitles are indeed there, by right-clicking and choosing "Domain Stream Attributes". This should show you the subpicture streams in the movie. If there's none, and would be the problem (but since you can see them on your soft player I'm sure you'll have some).
- Now go to the right panel, where you'll see the precommands and the post-commands (there are commands that are executed right before and after the video in the PGC plays).
- Select the very top line (**** pre commandsright click and select "Add after". This will insert a "NOP" command at the top of the precommand area.
- Double-click this NOP command to edit it. This will pop a small panel where you can modify the command. Select the menu "By Type" submenu "Set" - "SPRM" and "Subpicture". This changes the NOP into a SetSTN
- The SetSTN allows you to change the audio stream, the subs stream and the angle. In your case, you just want to adjust the subs stream. So select the "Sub picture" part of the dialog, click "Set To" and with the slider select which subpicture you want. Make sure "on" is selected! Click OK.
- Now save the DVD (File menu) and burn on a DVD-RW to test on your standalone.
It's more complicated to describe than it is to do...
Thanks for that, it was very simple to do.
Unfortunatley it didnt work. This is a real pain - I guess I will just have to watch it on my pc with no DTS
Thanks for you help -
sorry to hear that... I'm out of ideas too...
No audio devices showing up in Virtualdub. ASIO plugin needed??
By greggery in forum Newbie / General discussionsReplies: 3Last Post: 16th Apr 2011, 19:37 -
Subtitles not showing
By marukomu in forum SubtitleReplies: 17Last Post: 16th Nov 2009, 20:39 -
subtitles showing like chinese
By forare in forum SubtitleReplies: 1Last Post: 20th Aug 2009, 08:20 -
Subtitles not showing up. Perhaps a different process to be taken?
By martylavender in forum SubtitleReplies: 1Last Post: 12th Nov 2008, 17:14 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
