I had a DVD of my cousin's wedding and I asked my cousin to send me the DVD. He sent me all these files (see screen shot). He never told me how to put this onto a DVD.
Does anyone know what to do with these files?
first off, try using a more meaningful topic instead of "What do i do" or "Need Help"
then i would see if you have all the necessary files, try and play your dvd using powerdvd or windvd
if that works then i would add all those files to a folder called VIDEO_TS create a blank folder Called AUDIO_TS and burn the 2 folders to a dvd using recordmax which i got with my burner, use the burner software you have
there are lots of other ways to create the dvd, fill out your profile and do some reading on the left -
If in doubt, Google it.
