I am seeking recommendations on which program to use just to re-edit
the menus and chapter points for a DVD. I have use a DVD recorder to
transfer several VHS tapes to DVD format, and I don't need to edit the
main video clip in any way. I just want to replace the menus and change
the chapter points. Ideally, I'd like to only modify the VIDEO_TS files
and not have to change any of the VTS_01_* files.
Since I'm a little new to DVD authoring, I first should ask if this is possible.
And secondly, what program(s) can do this without any processing/
conversion of the main VOB files?
Thanks!
TMPGEnc DVD Author should be able to do it for you (amongst others).
If in doubt, Google it. -
DvdReMake Pro does not change original quality of video/sound. May be these two guides will be usefull:
http://www.dimadsoft.com/dvdremakepro/ht_insert_chapter.php
http://www.dimadsoft.com/dvdremakepro/ht_customize_menu.phphttp://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 20:42 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
