anyone know how to 'stitch' two movie files (xvid or divx) into one full dvd movie....newbie style :P
Use VirtualDub. Open the first Divx file, then choose the menu option "Load Additional Segments". Open the second Divx file, and it will be added to the first one. Click on DIRECT STREAM COPY for both the Video and Audio (VERY important) and save to a new file name.
Download a copy of DivX2DVD from VSO software http://www.vso-software.fr/download.htm
It's free and will quickly encode your newly saved DivX file into a compliant series of .VOB, IFO, and BUP files, ready to burn. -
Well you COULD use the above method (as long as both halves are using the same codecs/etc)
Or
Just convert each half seperately into mpeg or mpv/m2v + audio then import both into your authoring app (TDA is dead quick and easy) on the same track, starting with the first half.
This method cuts out an entire opp which is prone to many problems unless each appended part is likewise (res/bitrate/audio etc). -
I'm with monzie on this one - too often split files, especially those with AC3, don't join real well in Virtualdub - not all the time, but enough for me to not recommend it as my preferred method.
I always just use TDA to join - the ever so slightest of pauses between, but I can live with it if it means avoiding all the synch problems that can happen if you try to join the beforehand.If in doubt, Google it. -
Hey Jim, you're right. Better idea to combine the files when they're encoded into MPEGs.
Converting DVD to AVI...but to DivX, MPEG4, YUV or XVid??
By lnong in forum DVD RippingReplies: 1Last Post: 11th Oct 2009, 07:44 -
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 11:06 -
Problem of jerking in video while Converting DV to DivX / Xvid / DVD
By ckbasak in forum Video ConversionReplies: 7Last Post: 30th Dec 2008, 09:23 -
Converting Dual Layer DVD to Divx/Xvid
By Snorph in forum DVD RippingReplies: 8Last Post: 15th Mar 2008, 17:37 -
Can anyone recommend at good program for converting DVD to Divx or Xvid?
By gbgunner in forum DVD RippingReplies: 13Last Post: 10th Nov 2007, 18:18
