how do i add a menu to a already encoded dvd can this be done in tmpgenc dvd author, ie make a menu then import alongside the vob files
thanx
Hi muzzi,
As far as I know, it's not possible to add to an existing menu.
You'd need to rip the VOBs to your hard drive, load those into TMPGEnc DVD Author and do a menu of your own.
This method does not retain the original menu.
Hope that helps some...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Moving this to DVD Authoring ..hold onto something .....
Using TMPGEnc DVD Author, you can import each titleset off an existing DVD using the Add DVD Video button, and then make your own custom menu for it as you see fit. I cannot recall whether you must rip to your hard drive first if the material is already unencrypted, but it wouldn't hurt I guess.
If in doubt, Google it. -
If you know how thinks work in DVDs you may try using DvdReMake Pro. You can author whatever menu with whatever application you have, insert it into your already authored disk and add functionality to buttons you want them to have
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
adding a menu
By natty in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2010, 07:36 -
adding a Custom menu into a original menu
By Flarup in forum Authoring (DVD)Replies: 1Last Post: 30th Oct 2009, 09:38 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Adding menu to DVD
By randyj in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2007, 01:28 -
Adding DVD menu's
By wristar in forum Authoring (DVD)Replies: 3Last Post: 18th Oct 2007, 12:52
