I'm trying to figure out the simplest way to create a DVD. The DVD would be nothing fancy, just a bunch of captured video clips. Any help would be greatly appreciated.
The ideal solution would look like this:
- I have a bunch MPEG clips in a directory.
- I start a script (or simple program) that results in a DVD with all the clips included.
- Being able to specify a title for the DVD and chapter titles would be nice but not necessary.
What I would ideally like to do is to be able to tell someone to load a blank DVD and then start this program (or script). When it's done, they eject the DVD and go on their merry way.
The idea is a simple one step process to dump all the clips to DVD without requiring someone to manually author the DVD. If there's one product that can do this that's great. Alternatively it could be a series of applications that can be strung together to accomplish the same thing.
I'm also open to writing my own custom application. Any suggestions for an SDK/SPI? Will the Nero SDK/API work?
Any ideas?
https://www.videohelp.com/forum/viewtopic.php?t=248994
This topic's very similar to yours. It might be an idea to keep an eye on it
Basically it would be easy if you could find an authoring tool that can accept commandline input. I don't know of any that do, unfortunatelyIf in doubt, Google it. -
Are all the MPEGs in the directory the same type : All MPEG1 or All MPEG2 ?
If they're MPEG2, are they already DVD compliant (dimensions, bit rate, etc) ?
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 11:16 -
Simple DVD Authoring
By DeathStalker77 in forum Authoring (DVD)Replies: 22Last Post: 26th May 2010, 01:40 -
simple dvd burning
By pshngo in forum Authoring (DVD)Replies: 3Last Post: 2nd Jun 2008, 05:04 -
Again on Simple DVD authoring
By asadfx in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 07:22 -
Authoring a simple DVD
By asadfx in forum Newbie / General discussionsReplies: 2Last Post: 21st Nov 2007, 15:54
