Hello!
I got a DVD from Europe that is PAL, but im in America and we got NTSC system, and i see it white and black, how can i do to convert into NTSC? i had searched but i have not found anything, any idea????????
Easiet thing to do is to get a player that will play both Pal and NTSC. Check on google to see if your DVD player has a firmware upgrade to be able to play Pal DVD's. Also check here:
https://www.videohelp.com/guides.php?howtoselect=4;41#4;41 -
You didn't find anything ?????
There's probably one post per week on this topic.Want my help? Ask here! (not via PM!)
but my player cant do that, i cant buy another one...i need to do that conversion....
What is your player? If you complete the computer portion of your profile it really adds to the experience here.
Hello,
https://www.videohelp.com/guides.php?tools=&madeby=&formatconversionselect=&howtoselect...or+List+Guides
There are 8 guides in that link for you for pal-ntsc conversion.
There's a "How to" section on the left of the screen <---- It has a TON of info in itOriginally Posted by SeNdEr2005
this method did not work for me, https://www.videohelp.com/forum/viewtopic.php?t=221928 another one?
Since you are trying to convert PAL DVD to NTSC DVD I suggest you take a look see at this here thread:
https://www.videohelp.com/forum/viewtopic.php?t=219852
This is as close as I have ever gotten to writing a step-by-step guide.
Kudos to Xesdeeni who is the genius that figured it all out to begin with
You can find a lot of stuff these days on doing PAL to NTSC but back in the day when I used to look for this stuff Xesdeeni was the only one that had information on how to do this and his method for interlaced PAL to NTSC is still the best!
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
