My digital camera (HP R707) creates MPG video files at 320x240 @ 29.97 frames a second. The audio track is 44 KHz mono @ 96 Kbps.
When I play back this video through the xbox media center software the audio is nothing bug sharp crackling / popping (fine when I play through my pc).
Is there any way for me to convert just the audio track inside an mpg file?
What software could I use to do this.
I was playing around with VirtualDub and it would appear I could do it by converting the mpg to an avi (and converting the audio at the same time) and then converting the avi back to an mpg but this seems like a real pain.
Any tips would be appreciated.
Darryl
I would simply de-mux the .MPG file (use TMPGEnc, etc) , then convert the extracted audio to something compatible w/ your XBox (not sure what the requirements are...), then re-mux the original extracted video with the processed audio.
You can't fool me, I'm a moron!
How to convert PCM audio track inside M2TS file
By majouz in forum Software PlayingReplies: 1Last Post: 20th Jun 2011, 15:24 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
How do I convert an mpg file using AC3 to use MPA instead?
By bmoret in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2008, 10:19 -
How to convert an mpg file to avi
By spyros in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2008, 16:02
