HI ,
I justt started with this cobination of DVD2SVCD and Cinema Craft Encoder. Wow.....what a Quality!! The best untill´ now! (I think ).
I´m using C C E 2.5. It seems this is a trial version.
´Cause in the final result there is a logo of this in the down right corner.Does anyone know how to get rid of this??
Other Question: I´m having trouble with the subtitles.
After multi-plexing it in TMPG ( The mpv file to MPEG).
The subs are gone.
I hope someone can help me...thanks Already
to get rid of the logo u must buy the full version of CCE 2.5...or you can look around and you might find the full version
Hi marhart71,
Where to download DVD2SVCD and Cinema Craft Encoder?
Thanks!
Yuan -
DVD2SVCD can be found here
http://dvd2svcd.doom9.net/
CCE has to be found by you - I suggest getting on the newsgroups - use http://www.usenetserver.com or http://www.giganews.com
or purchase it - please do not ask any more detailed questions about finding CCE
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
