Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 75
Thread: 352 vs 720 resolution at 2700 Kb/s
  1. #1
    Preservationist davideck's Avatar
    Feb 2003
    USA
    Posts
    1,226
    Last night, I did an A/B comparison of two 20 minute captures of the same source segment, one at 352x480, the other at 720x480. Both bitrates were 2700 Kb/s. I was capturing a Beta III recording through a TBC-3000 to a PVR-250, trying to fit 3.5 hours onto one DVD. I burned them to separate DVD-Rs and compared them simultaneously using two DVD players and a PIP TV, swapping between the captures every several seconds or so. Then I exchanged the DVD-Rs in the DVD players and did the A/B comparison again. IMHO, the 720x480 capture looks better. The images were sharper, and more detail was preserved. Any areas of blockiness were more pronounced at 720, but this seems directly related to the extra sharpness obtained at that reolution. I think it would be very hard to tell the difference if you weren't comparing them side by side. Would anyone care to clue me in on the advantages of capturing at 352?
    Video Restorer lordsmurf's Avatar
    Posts
    30,811
    No.
    An observance of 720 being "sharper" is DIRECTLY related to the hardware, software and source. You cannot surpass the resolution of the source (maybe if you use a detailer, but that's a whole different conversation). Most sources are at, under or around 352x480. Almost nothing aside from DV is available to the consumer in that higher res.
    Macroblocks are an artifact created from lack of bitrate. 2700k is a SERIOUS lack of bitrate for 720x480, and can even be a bit to low for 352x480.
    Offhand, I have no idea what the source res is for a Beta III tape. I'm not familiar with that format. It may be high res.
    Your DV box only captures 720x480, DV is that res. If you saw softening of the footage at encode, blame the encoder.
    If it was the Hauppauge PVR doing MPEG encoding, those boxes are slightly soft. Same for MainConcept (unoptimized) and TMPGEnc.
    Double digitizing the signal (first to DV) and then to the PVR-250 was probably very damaging too. You have a DV box ... transfer it.
    Hope that clears some things up for you.
    Member
    Nov 2003
    NYC
    Posts
    548
    I have done my own comparison with VHS and analog cable at 352 vs 720 and quite honestly I do not see any difference when the source was vhs between the 2 resolutions. I do, however, notice a somewhat sharper, clearer and more detailed picture when the source is analog cable. What is the source resolution for analog cable? Is it higher than 352 (I realize a resolution of 352 is NOT the same as 352 lines of broadcast resolution) I am just wondering approximately how much detail you are losing if you cap analog cable at 352?
    No, I'm from Iowa. I only work in outer space.
    Posts
    30,811
    It's in the low 400's at best. (440x480, max possible in theory ... often nowhere close in practice) ... 352x480 is going to be pretty close
    Member
    Nov 2003
    NYC
    Posts
    548
    Thanks. I figured it must be slightly higher since 720 seems better than 352
    Member Cornucopia's Avatar
    Posts
    15,966
    Beta III is, if I'm understanding his reference correctly, Betamax LongPlay (LP) speed which give ~3.5 hours to a tape.
    While Betamax is somewhat of a better signal than VHS, you're still starting with an LP recorded signal. My guess is that the nearest equivalent resolution you can resolve this signal to is ~ 300x300. (Off-tape blurriness reduces 480 lines to visual perception of ~230 in VHS, I expect more for Betamax.
    BTW, analog signals don't have a "resolution" as defined the way digital signals do. They have a bandwidth and an equivalent resolution can be approximated with TVL charts, etc. I'm really getting tired of people throw around numbers for analog signals (Betamax, VHS, LD, Betacam, SVHS, Analog cable and broadcast, etc.), when there is so much variability.
    Feb 2003
    USA
    Posts
    1,226
    Yes, Beta III is the LP version of Betamax; 4.5 hours with an L750 tape. It has more detail than VHS SP at roughly the same noise level.
    I am wondering under what conditions a 352 capture would yield better results than a 720 capture at the same bitrate. From the replies so far, it seems like 720 is the better choice, regardless of source detail.
    Posts
    30,811
    Quote Originally Posted by Cornucopia
    BTW, analog signals don't have a "resolution" as defined the way digital signals do. .
    That's a given, but they have approximate equivalents.
    Quote Originally Posted by davideck
    No. To upsize that much is to create new data, which in turn creates new artifacts. One of the most predominant ones is linear errors of sorts.
    Beta 3 and VHS have the same bandwidth (afaik).
    Feb 2003
    USA
    Posts
    1,226
    Wilbert - I believe you. What I should have claimed is that the BIII recordings that I have made play back with more detail than the VHS SP recordings that I have made. Probably depends on the particular VCRs used.
    Nevertheless, it seems to me that for a given source and bitrate, if the 720 capture looks sharper than the 352 capture, then detail is being lost at 352.
    Member The_Doman's Avatar
    Feb 2004
    Netherlands
    Posts
    782
    That's just my experience too. 720/704 looks so much better for me, even on VHS sources. (Using PAL with a D8 camera er and a Pinnacle 848 card)
    I always go for the better resolution. You really can't define a ANALOG (cable/VHS) source in a fixed digital resolution. Specially with VHS sources there can be a lot of difference in quality depending on the VCR being used.
    And about that bitrate of 2700, depending on the source material you can do some nice things with Procoder and a 2passVBR. I often make recordings (tennis) of over 3 hours in full resolution that way.
    Damn I really get tired of this one.
    These comparisons of 352 versus 720 captures, and the sources involved, (surprised no charts or graphs yet) are ignoring the most important aspect. YOU ARE ASSUMING A PERFECT CAPTURE!!!!! If you actually have hardware that does this, skip the rest of this post.
    It has been widely discussed on this board, lots of sample pictures, factual info on exact procedures followed by hardware, etc., etc. The simple fact is that almost all capture hardware caps at a fixed res, usually in the vicinity of 640 x 480. When a lower resolution is specified, the card applies internal resizing algorithms, and often various smoothing filters, which result in a LOWER QUALITY VIDEO. Detail is not lost, it is captured and then destroyed.
    It doesn't make a damn bit of difference what the res of your source is, other than a lower quality source somewhat "masks" the quality loss.
    I am constantly amazed at the way many supposed "experts" continually ignore these facts, which have been repeatedly demonstrated both by simple visual comparison, and by technical info which clearly shows what the true issues are.
    I saw my first post on this over two years ago, and ran my own visual tests confirming the problem. Hardware technical reference info was posted over a year ago. People bitched at me for decrying this reliance on theory over observation, I don't care what the charts and graphs say. I determine what is best by actually looking at it, A-B comparisons, with confirmation from others. 352 caps are worse than 720 caps, PERIOD.
    BTW, whether 2700 is sufficient bitrate depends entirely on the source, for lo-motion, this could be acceptable.
    Posts
    15,966
    Yeah, that's one reason I always cap at 720x480 (I have the drive space) and resize in software (Vdub, AVISynth, TMPGEnc, AE, etc) if needed. And I've got great cap boards! (Canopus DVStorm2, AVIDs)
    Posts
    30,811
    Quote Originally Posted by Nelson37
    You destroy your own argument with this ascertion.
    Well, that pantload of information certainly helps clarify the situation.
    Perhaps I should have specified "with my capture hardware", and added that same is true with most, but perhaps not all, capture hardware. Though I already had stated that possible exception earlier, and just assumed that anybody with the brains God gave a walnut could make the necessary extrapolation.
    If you have some information which contradicts the known, previously posted in great detail, hardware reference data which specifies the problems capping lower res video, which is common to virtually all cards, then I and probably many others would be interested in seeing it.
    Member
    Posts
    434
    Well, I would certainly like to see this issue cleared up. I've read comments similar to these from Lordsmurf before, and while it didn't really register at the time - I found it puzzling when I thought about it later.
    First: I'm not sure how one can talk with certainty about the horizontal resolution of analog video. Vertical resolution is of course determined by the number of lines, but horizontal? I freely confess ignorance on this subject - I can think of iron oxide grain size etc, but otherwise I don't know what limits horizontal resolution on a purely analog VHS recording system.
    Second: even if some chart says that the effective horizontal resolution on the VHS tape is 352 pixels, that IMHO still implies that you should capture at 720 pixels minimum - ie. at the Nyquist rate, otherwise the signal will be aliased, and the error distributed as noise over the residual lower frequencies. If you claim that you can capture at 352 pixels per line and not lose definition then that would imply that VHS only has an effective horizontal resolution of 176 pixels, which I find hard to believe.
    Like I said, I wish some knowledgeable person would clarify...
    Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    Posts
    821
    I think what LS is driving at is that you cannot make a blanket statement like "352 caps are worse than 720 caps, PERIOD" and be correct in all cases.
    For instance, if you are trying to capture a source with lots of fast motion, and fit it into a given file size, you may not be able to use a high enough bitrate to keep the 720 cap from macroblocking badly, whereas if you had capped at 352, the bitrate you can use for the given file size would be enough to prevent the occurrence of macroblocks. In that case, the 352 cap will look better in the end analysis, even if for the sake of argument, you have lost some detail capping at that resolution.
    Mpack - reference to #1, analog doesn't really have a resolution, but we can speak of equivalents. Important factor here is that resolution "overkill" on capture does NOT involve a resize operation, it is simply using more sampling points than may be theoretically necessary.
    It is generally accepted that VHS "equivalent" resolution is somewhere below 352x480. That's where all the charts and graphs come in.
    #2. I've seen this discussed, more charts and graphs again.
    The factor that overrides all this concern about source res lies in the nature of how most capture hardware works. They use a FIXED resolution. That's it, done deal. They use a resizing algorithm to arrive at designated res, this algorithm being in virtually all circumstances notably inferior to post-capture resizing. Some cards also apply filtering, and the same inferiority applies.
    The observed visual defects caused by these processes vary by card, and by specified resolution. The "trigger point" resolution where they become really objectionable is usually somewhere below 480x480, and almost always above 352x480. That is SPECIFIED resolution, the actual or apparent resolution of the source does not matter.
    These hardware specs were well discussed and documented some time ago. I haven't searched for it, but it's there for all to see.
    For instance, the actual fixed capture res for ATI cards was either at, or very close to, 688 x 448, which fascinatingly is the exact res you get when specifying a 720x480, cropped, DVD MPG-2 capture. Amazing, ain't it?
    Brainstorm, I'll concede the point, but I would think it is a given that 720 res requires more bitrate than a 352 cap.
    In fact, no I don't concede this. You're invalidatng the 720 cap for a reason outside the principles of the discussion. Since those wishing a 352 solution are using that as the targeted goal, it is obvious that a 720 cap would require a resize to reach that goal. Therefore, a re-encode is necessary rendering capture bitrate irrelevant.
    You might as well argue that 352 is better if the cable is unplugged when doing the 720. Or that you really need an 80 x 60 file for Web broadcast.
    Or that the filesize must fit on a floppy disk.
    OK, restatement - Assuming necessary changes in bitrate are made, and you are testing both on the same source, resulting filesizes fulfill your needs, and best quality is your goal, with virtually all known capture hardware and specifically ATI AIW cards, then 720 is better than 352 for capturing purposes, PERIOD. How's that?
    Posts
    30,811
    ATI's clock in at about 704-710x486 ... FYI.
    Aug 2002
    Texas, USA
    Posts
    821
    I could have sworn this thread started with a question about 720 vs 352 at the given bitrate of 2700 kbs.
    Ah, crap, I forgot.
    He did, however, note that the 720 cap in fact looked better.
    The actual question was what advantages there would be to a 352 cap. Accepting the given of lesser bitrate usage, I still think the disadvantage of hardware-induced degradation outweighs this.
    It is the overlooking of this degradation, and continual (incorrect) citation of source resolution as the important factor, that I am arguing against.
    Posts
    30,811
    Ah, crap, I forgot.
    Huh? A bit too much rhetoric, hard to understand what you're saying.
    Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Posts
    11,301
    This thread has gotten very "messy" so let us get back to the basics.
    A cap of 720 width is almost always going to look better in terms of sharpness and detail than one done at 352 width.
    You could argue all day that the source maybe doesn't have enough resolution for 720 width to look better but at the end of the day it will. End of story.
    So issue ONE is the resolution in terms of SHARPNESS and DETAIL of the image.
    Issue TWO is the MPEG compression.
    The benefit of 352 width over 720 width is that you will get much less MPEG artifacts (such as blocking and mosquitoe noise etc.) when using a low bitrate. I am sure we can all agree that a video bitrate of 2700kbps is a low bitrate for a width of 720
    So in this particular situation (2700kbps video bitrate) I cannot imagine for the life of me that the MPEG artifacts in the 720 width capture are worth the extra sharpness or detail of the image. In this case I would rather have the ever-so-slightly softer look of the 352 width capture which would have MUCH less MPEG artifacts.
    - John "FulciLives" Coleman
    Posts
    30,811
    Let me be brief and frank...
    to expand on what Fulci said...
    More pixels needs more bitrate. That easy.
    A 352x480 cap at 3500 will look equal to
    a 704x480 cap at 7000
    Easy as that. Simple, huh?
    2700 is already low for 352x480
    it will be unbearable and full of blocks at 720x480
    5400, on the other hand, would be more acceptable
    While 720 is higher res, and thus sharper, it only works out that way if the source was that sharp too. VHS isn't very sharp. Unless you buy an image enhancer (like the Vidicraft Detailer or SignVideo DR-1000), that's not going to change. There is no magic in the capture card.
    On the other hand, film in a studio is high res.
    That's why people at home use 352x480 and commercial releases are 720x480. Stick to your source, and you'll be fine.
    The only exception is probably half or more of the video cards out there suck. They cannot accurately capture, and most of them look better at higher res. This is why buying good hardware and software is of utmost importance.
    There are some bitrate graphs halfway down this page:
    http://www.digitalfaq.com/capture/avivsmpeg.htm
    Member vhelp's Avatar
    Mar 2001
    New York
    Posts
    7,716
    I think everyone has good points.
    But, I believe that it's all about *sample* rates and how much detail it
    returns back (after the cap/hardware induces it's own level of algorithems
    and things, aka 'taintedness') ...
    And, the greater the resolution (max the given cap card was destined/set
    to) the better the results.
    Course, now that given the above, resizing is another deal all together.
    Given a good *sampling* of a capture (assuming the disccusion is w/
    respect to VHS sources) the recommneded (mine at least) for VHS sources
    to capture in (bare in mind the cap cards limits) the resolution should
    always be "highest" your card or driver will allow. That means, if your
    card can do 720 pixels, then set it as such. But, if your card does a
    little "funny jimmy", then you have to employ trickery, such as caping
    at odd sizes to get to the same goal. What ever that is. I'm saying
    here, that capture cards have a funny way of yielding final results. And
    we can all say, that its dependant upon the card and its feature (or
    limits)
    If your capture card does a good job at *sampling* at a resolution
    setting of 720 pixels, BUT that your end goal is for another
    product (and for other pobably obvious reasons) 352 x 480 res, then
    your chances are, that you'll get better results if you HAD capped
    at 720 vs. 352 res/pixels (or whatever)
    Sampling ...
    I beleive that the secret (and misunderstanding) w/ respect to resolution
    is the *missing link* .. and that link is called sampling
    For instance, when we capture something from a tv source (actaully, any
    source really) we are not capturing resolution. The device is taking
    samples and incprorating them (however the machnics/ciruitry is done)
    and applying them to this timeline (resoution of dots/pixels) within
    a container or two-demenion plain, and resulting in what we see (or
    perceive as resolution) oh my
    I've ben plauged by this resolution theory for time ends, when talking
    specially with VHS sources. But this applies to everything that we
    capture - videowise. we are not capturing a resoution. WE ARE actually
    sampling dots or 1's and 0's and the machincs of things (inside the
    device) is puting each 1's and 0's in their respective places. that
    mean, all the LUMA and CHROMA and what ever else there is to *fill*
    this timeline (or container) with.
    so, when we talk about resolution, think of it, in terms of containers
    hold dots.. or drops of pee-pee
    Then, w/respect to resolution..
    * the better the sample circuitry the better the results
    * the greater the resolution (for the samples of pee-pee) the greater
    .. the detail (or smell)
    When your capture source is VHS, the same is applying. Or shoud I say,
    when you capture a TV source the same applies (w/ respect to sampling)
    Some cards do a better job a sample the source. Others' do a better
    job at interpolating the data. Others do a better job at... etc.
    It all depends on the card and it's features and abilities (or limits)
    Do you recall those newer cards that are 10bit (vs. 8bit) samplers ??
    That's another hint to you.
    It's *sampling* the detail (or color information) but at 10bit
    units vs. 8bit units. There is obvisiouly going to be better results
    w/ a 10bit sampler than an 8bit.
    But, this sampling, takes a certain container of color infomation
    and samples out of the millions of collors (or given pallete) and
    sample at a *greater resolution* (demention) of colors and picks
    out those that are closest in detail of the original source's.
    Now, on the speaking of 352 vs 720 (w/ respect to MPEG and Bitrates) ...
    I agree w/ fulci and LS on this. However..
    No one is wrong here. Think about it for a moment.
    * 352x480 cap at 3500 will look equal to
    * 704x480 cap at 7000
    This is true. However, it's only theory, because as we all know..,
    and based off of experience, that its the encoder that dictates this
    theory to be true or false. What I mean, is given the above, will
    the encoder in use, fullfill the theory above 100% ..and the anser is
    yes/no
    It all depends on the encoders engine.. or algorithem and how it
    utilizes bitrates; modes; and thechniques in its encoding process
    and final MPEG quality/detail (if you're measureing fast scenes as
    a final guage)
    There is nothing wrong w/ finalizing projects to 352 x 480 res.
    (after considering the above)
    But do bare in mind, that today is DVD. And Todays' tvs are getting
    bigger and better, and will require better/greater details from
    our louzy processed MPEGs (our captures/encodes)
    No matter how good your source 352 is, and into these tvs of today (and
    tomorrow) chances are, you'll be back here looking for resolutions
    (I mean, answers) to improved details from these sources.
    But, I think the argument is w/ respect to 352 vs. 720 AND the bitrates
    used (as posted'er above started on)
    I think that the answer should have ben better responded to w/
    repsect to Methods of Encoding from w/ Bitrates and formats from
    these two resolutions. It wasn't about capturing resolution (at least
    I don't think so) It was about Encoding Technques for either res
    Cheers,
    -vhelp
    Member
    Australia
    Posts
    665
    Well I do all my TV & VHS captures at 352x576 (PAL) because in the time it takes to render a single pass of 720x576 I can have 2 passes of 352x576 completed, fully authored and burn't to DVD. And playing it back on an analogue TV there is no visual difference, so why bother with Full D1 sizes. :P
    Posts
    15,966
    I pretty much agree with what you said, but to clarify:
    Quote Originally Posted by vhelp
    352x480 cap at 3500 with exhibit (roughly) the same amount of artifacting as
    704x480 cap at 7000
    Resolution would still be higher with 704.
    So at same bitrate (~2700), example of "Artifacts = K * Resolution / Bitrate" and "Quality = Resolution / Artifacts" so e.g. 352/200artifacts = 704/400artifacts.
    "K" is determined by the efficiency of the filter/resizer/encoder.
    Mar 2001
    New York
    Posts
    7,716
    oops.. I applogies.
    I was capturing (of all things) cut/pasting the data
    and didn't revise it.
    352x480
    .. vs..
    704x480
    I ment that I agree to an extent on the two w/ respect
    to bitrate, etc.
    I'm a Super Moderator johns0's Avatar
    canada
    Posts
    12,226
    Trying encoding a football game at 720x480 at 2700kbps they you will see the flies following the football players in fast action scenes.
  1. DVD resolution is 720 x 480 ??
    By siratfus in forum Video Conversion
    Last Post: 3rd Mar 2013, 09:47
  2. Philips BDP 2700/05 - region code hack???
    By MAC-IRELAND in forum DVD & Blu-ray Players
    Last Post: 30th Nov 2011, 09:00
  3. What Windows resolution for viewing 720/1080 MKV's?
    By leopardx in forum Newbie / General discussions
    Last Post: 9th Apr 2009, 19:43
  4. Newbie question about 720 x 480 dvd resolution
    By siratfus in forum Newbie / General discussions
    Last Post: 15th Aug 2008, 17:30
  5. dvd plays at 720 x 576 but when ripped goes to 352 x 576 and is squashed
    By aljolson in forum Newbie / General discussions
    Last Post: 8th Jun 2008, 11:54
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
