My PC has WinNT 4.0. When I try to play VCD using Windows Media Player 6.4, it can play the first few .dat files but while trying to play the last .dat file, it gives an error like "No combination of filters could be found to render the stream.". When I play the same VCD in Xine player on Linux 7.1, it is perfectly alright. Give me idea about the right player I have to use. For some other VCD, WMP gives error messages like "Cannot open. Please verify that the path and filename are correct and try again. (Error=80040216)". Please help me.
Dont get hassled cause you cant play it, download VCDGear from utilities section and convert .dat to .mpg, then tell me if it works
good luck!
I have a similar problem. I tried using VCDGear, but it won't convert past a certain point. VCDGear will just stay at that mark for a long, long time without moving.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 10:55 -
Cyberhome 300 problem after playing VCD discs...
By MrCairo in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Mar 2011, 18:57 -
Playing VCD on Computer or convert to DVD
By corumz in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2008, 06:35 -
Is there any free VCD playing software which meets my requirement?
By csh in forum Software PlayingReplies: 11Last Post: 20th Dec 2007, 02:21 -
VCD MPEG playing won't work in WMP11...
By fabvideohelp in forum Software PlayingReplies: 6Last Post: 22nd Nov 2007, 13:25
