Hi,
I would like to know how I can back up the *.DAT files I have in VCDs into AVIs.
Thanks you in advance.
If in doubt, Google it.
You should be able to open the DAT files in Virtualdub and simply reencode them with the Audio/Video codecs of your choice.
BG
BD Rip worked only once, now can't rip BDs successfully
By thestrangebrew in forum Blu-ray RippingReplies: 2Last Post: 1st Apr 2012, 09:30 -
Join 2 AVIs
By phunkidude in forum MacReplies: 2Last Post: 23rd Dec 2010, 15:28 -
my rip spec hell - from a ts. folder to rip specs - how?
By marinebc11 in forum MacReplies: 5Last Post: 26th Nov 2007, 21:28 -
How can I join several AVIs into one?
By htp367 in forum EditingReplies: 2Last Post: 30th May 2007, 11:06 -
hi-def avis on HDTV
By spurty in forum ComputerReplies: 5Last Post: 22nd May 2007, 10:59
