  1. I have mpg 1 movie ,it has two language ,is way to erase one language?
    two language audio,how can I take one off?
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Are we talking audio ? subtitles ?
    A little bit more information, if you will
    If in doubt, Google it.
  3. If it is subtitles - no unless you crop (black out) the on screen letters. If audio - yes there are a few ways.
  4. yes it is audio
    can you tell me how?
    Dec 2004
    Australia
    Well for MPEG1 it would generally just be two mono tracks (one left, one right), so just kill one and duplicate the other.
  6. How ? use what program?
    thanks
    Dec 2004
    Australia
    However you like. As with most things, there are numerous ways to go about it.
    I guess just demux the mp2, open with say adobe audition, delete the channel you don't want, replacing it with a duplicate of the other. Convert back to mp2 with say toolame. Lastly multiplex back with the original video stream.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    I would think that possibly goldwave or audacity might be able to do this.
