I just bought a Phillips DVP 642, and I am trying to play this XVID MPEG 4 file, but it's garbled and pixelated when played on the DVP 642 It is fine when played on my computer using Windows Media Player 9.
Good advice needed.
Results 1 to 11 of 11
Could your problem be the well known pixelation problem with some xvid files?Originally Posted by molebdynum
When the video plays press system/menu on the remote and then press it again. See if that makes it go away. If it works then it's a common problem which will return everytime you restart the video or sometimes when you fast forward. Just repeat the trick. As far as I know the cause is still unknown and has yet to be resolved with any firmware upgrade. -
Could be a problem with a custom quant matrix. You can check what matrix was used with MPEG4 Modifier. Will also report the XviD bitstream version, whether bframes, qpel or GMC are used, etc.
gl99, I pressed the system menu button it it's all good thanks for this neat little trick.
jimm.. yes it is.. ive had mine for a few months and it does that every so often.. only on some xvid disks.. its a quick press of the button and its gone.. phillips must know.. but 2 F/W releases have not fixed it..
My pleasure. I'm just passing on some info I picked up in another thread that helped me solve the same problem. All I did is make the connection with the problem you described.Originally Posted by molebdynum
@Jim
just to add to Heywould3's comment: It's come up in a number of threads here which drew quite a few comments so I guess it's common lnowledge with many dvp-642 owners and users at videohelp
Problem with philips dvp 642/37 after choosing progressive scan option.
By vinland in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Jun 2010, 20:21 -
Philips DVP 5140 or DVP 642/37, which is better?
By Amuse in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Feb 2008, 17:26 -
how to encode MPEG4 to play on a phillips DVP-642 player
By thejunkman12 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2008, 09:32 -
Philips DVP 642 (37A) dvd player -does it play PAL
By Katiemay in forum DVD & Blu-ray PlayersReplies: 8Last Post: 12th Jun 2007, 00:16
