Results 1 to 9 of 9
    Jan 2004
    There is no video showing in the preview window in DVDWS 2 with the latest update patch after I installed DirectX 9.0c,,, any ideas??
    mike
  2. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    uninstall it ?
    yeah ....
    I know ...
    If in doubt, Google it.
    Jan 2004
    how? I don't know how to uninstall directx ?
  4. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    From what I could find using a google search, you can just install 9.0b and it will remove 9.0c automatically.
    Get 9.0b from here:
    http://www.oldversion.com/program.php?n=directx
    Jan 2004
    well I tried that, didn't seem to work and the installation was wayyy too fast for it to have installed anyways...
  6. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Try Start menu... run... dxdiag
    It will show you what is installed. The bottom of the main panel should tell you which version you have. Lots of valuable info.
    Jan 2004
    yes it's 9.0c
    DVDWS2 was working fine with 9.0b
    now what?
    May 2003
    Peterborough, England
    I've always had to re-install video software after upgrading DirectX. Try re-installing DVDWS2.
    Jan 2004
    yep that was my next step, seems like that's the only thing that might work at this point, thanks =)
