Hi.
I ripped a movie, Crazy Beautifull, and when playing back the VOB in my Software DVD, its missing sound in a couple of the VOB's. Any ideas why?
When i continue on and ,make the MPEG its fine all the sound is there.
I like to just rip the VOB so i can watch new release rentals later on, and then dont have to worry about returning them.
Any suggestions??
Robert
when you rip the dvd to your hd be sure to include the ifo files also and then put all files in folder called VIDEO_TS on any partition and then use windvd and select that partition as default dvd and you can play the dvd as usual with all menus and extra.
http://www.vcdhelp.com/plaympg.htm#dvd
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 15:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
Converting PAL VOB FILES TO NTSC VOB FILES...
By mmmipa in forum Video ConversionReplies: 3Last Post: 5th Apr 2008, 17:15 -
*S.O.S* No Sound when burning VOB-IFO-BUP Files to dvd
By Zaii in forum Newbie / General discussionsReplies: 3Last Post: 30th Jul 2007, 04:46
