I'm using DVD decrypter to decode to HD and VobBlanker to remove Extras and then compressing with DVD Shrink. Some movies have 2 or 3 different Angles which seem to display the same movie (I see no difference). Is there a way to remove one of those Angles to have more space for better video quality in the movie? Can it be done with VobBlanker?
Danny
There's an option in DVDDecrypter
that should remove them for you.If in doubt, Google it. -
This solution can actually mess disk navigation in some cases, but it will work for some disks
http://www.dimadsoft.com - home of DvdReMake and MenuEdit tools
How to remove subtext from movie
By striker9 in forum Authoring (DVD)Replies: 4Last Post: 12th Aug 2010, 04:06 -
how do i remove an angle lock from a dvd
By animalia in forum DVD RippingReplies: 1Last Post: 10th Jan 2010, 03:11 -
help, for remove the language letter which appear on the movie.
By flowerhorn in forum Newbie / General discussionsReplies: 3Last Post: 29th May 2008, 00:07 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
REMOVE Phillips DVP-642 "angle" indicator
By gumbico in forum DVD & Blu-ray PlayersReplies: 35Last Post: 28th Jun 2007, 12:55
