hey
Well I've gone and burned one of my partitions with nero backitup, I used the compress file option because I'm cheap and want to save dvds. So, now when I want to open my files off that disc, its just .dat files and an .exe, which was expected. The question I have is that, whenever I try to run the exe I get:
F:NRESTORE.EXE
G:\WINDOWS\SYSTEM32\AUTOEXEC.NT.The system file not suitable for running MS-DOS and Microsoft Windows applications. Choose close t terminate the application.
Sooo where do I go from here? Does anyone know of a guide, faq or forum anywhere that tells you what to do here? Thanks very much!!
Matt.
my buddy had a problem like that.....i dont know what he did......but i remember he had to contact Ahead's tech support......
Nero 9.2.5.0 - Can't burn anymore (error message enclosed)
By rock_king_my in forum Newbie / General discussionsReplies: 9Last Post: 14th Apr 2009, 11:02 -
Strange Error Message when trying to encode to DIVX
By Meiso in forum ffmpegX general discussionReplies: 1Last Post: 1st May 2008, 10:20 -
nero backitup problem (sort of video issue)
By ecc in forum ComputerReplies: 10Last Post: 7th Oct 2007, 08:50 -
Strange error message when re-authoring with TMPEGEnc DVD Author 1.6...
By justin81 in forum Authoring (DVD)Replies: 3Last Post: 24th Sep 2007, 02:23 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 02:01
