How do you export a still frame from a video. Are there any programs i would need for this? Thank you
Well, it depends on what type of video it is. For avi or mpeg, you might try HyperSnap or Camtasia, although you'll want to take the graphics acceleration all the way down on the player your using. For dvds, Womble is the easiest, but you usually have to rip the vobs to your hard drive first. Not all of the vobs, but at least the one with the image that you want to capture.
"I'm Batboy" -
You can capture single frames with WinDVD by hitting the P-key. The frame will be saved as 352x288 .bmp in a windvd subdirectory. Since windvd plays mpg as well as avi, this is quite a good solution.
Extracting frames from single PGM file
By lchen in forum MacReplies: 0Last Post: 18th Jun 2010, 05:49 -
What tool to save single frames as JPGs from video playback?
By zdvd in forum Newbie / General discussionsReplies: 3Last Post: 7th Mar 2010, 03:56 -
Cutting a M2V file or editing SINGLE FRAMES of it
By lorix in forum EditingReplies: 3Last Post: 13th Nov 2008, 04:05 -
How to remove a single or more frames from a DVD
By justmehere in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 13:06 -
inserted frames without dropped frames in VirtualDub capturing VHS
By whschlebaum in forum Capturing and VCRReplies: 0Last Post: 23rd Aug 2007, 21:59
