If i was to get this combo
http://www.bzboyz.com/store/product2938.html
Is this a good mobo cpu?
and how fast is the CPU in GhZ?
Thanks!
Results 1 to 19 of 19
Are you planning on buying the combo from that company?
Check this out first..................
http://www.resellerratings.com/seller2048.html
____________________ -
That is a good motherboard (not very good) but the CPU is very good (who cares about frequency if it`s better then a 3200 Ghz Pentium ? And it is much better then the 3200 Pentium ! ) But the great news is you can install WINDOWS 64BIT ( The Best ) !!!! It`s a hole new world there !!!! (You`ll have some problems with drivers). Also you can use XP on another partition of the HDD for games...In a CPU speed (Ghz) is nothing without intelligence... Bye!
Question. If you're buying all new, why go with socket 754 over socket 939? Socket 939 has a longer upgrade path and supports more bandwidth than socket 754. Just some comparisons at AMD's website.
http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_9485_9487%5E9492,00.htmlNothing can stop me now, 'cause I don't care anymore. -
It may not run 64-bit Native, but you'll still have the benefit of 32-bit processing and I'm sure XP64 will support 32-bit apps. There's not much call for an OS that runs only a handful of apps that aren't compatible with much else.
That's what Macs are for.:P
(Yes, I know there are plenty of apps; just not nearly as many as PCs.)
Damn it... I can not find the video of "Gaming on a MAC" .... all the really cool games like... well .... there is Zork.
JSB -
OK, so where can i get a combo with a AMD 3400 for around 300$? I can wait on the RAM. i just want to buy the cobo now so i dont waste my saved money on somthing else.
A plus would be that the company that sells it also builds it for you and puts the BIOS in as i dont really know how to do that! Thanks for the Help.
there is this oneOriginally Posted by JSB
http://www.apple.com/games/articles/2004/11/worldofwarcraft/"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
don't forget to mention that the windows xp 64 bit os is free right now for the first year
http://www.microsoft.com/windowsxp/64bit/evaluation/upgrade.mspx -
still beta though
I ordered from BZBoyz about 3 years ago with no problem, but after reading the reviews, I wouldn't order from them now. I just ordered an AMD ATHLON 64 3200+ w/fan and it came with that same motherboard, the ECS 755-A2. I only paid $203.00 total. I've been using ECS motherboards for 3 years now. I have 2 of them. Never a problem, no defects.
Thanks HatchetMan for posting that link for Windows 64bit. I didn't know that was out there. When I receive my new computer, I'll be installing that. I'm also getting a SATA 200 GB hard drive. I'm excited. -
I only got the motherboard and chip for $203.00. I got it at http://www.pcontime.net. Of course, I just ordered it, so I haven't received it yet. I'll be curious to see if it arrives in a timely manner and if it works.
Did you read this? Just curious! ...............Originally Posted by briandugas
http://www.resellerratings.com/seller7982.html
OUCH!
Hey little goober, there's a good company called Newegg.com!!!Originally Posted by gooberguy
:P :P :P
I have that exact ECS board in a render box at work. It works OK, but the bios choices are quite limited. I'd suggest the following:
http://www.newegg.com/app/ViewProductDesc.asp?description=13-136-147&depa=0
http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-484&depa=0
BTW, these AMD 64 Systems are FAST, and they run COOL.
I just ordered a magicjack and was wondering if anyone else used one
By johns0 in forum Off topicReplies: 9Last Post: 4th Oct 2010, 01:46 -
Was wondering if such a thing exists....WAN (Wireless USB connector)
By SE14man in forum Newbie / General discussionsReplies: 4Last Post: 3rd Oct 2010, 03:53 -
left wondering ... which capture device ?
By hydra3333 in forum Capturing and VCRReplies: 4Last Post: 2nd Dec 2009, 02:23 -
i have this mp4 and i was just wondering....
By tryvora in forum Video ConversionReplies: 2Last Post: 30th Jan 2009, 22:04 -
Just wondering why h.264 support in mobilephones is a NO-NO in the US
By bacardi/avt in forum Portable VideoReplies: 10Last Post: 2nd Nov 2008, 13:58
... nice.
